| BillL |
01-06-2020 12:41 PM |
Originally Posted by avrojockey
(Post 1397987)
Dan...I'm not sure if this is a common technique and maybe the amount I'm getting is from my abnormal technique. I cut open filter and visually inspected and found only a few very small (< 0.5mm) pieces of carbon. Visually the filter medium was very clean. Even after washing and letting it dry out in the sun I was only able to find a couple extra very small specks of carbon and still no metal of any variety.
When washing the filter medium in the mason jar I used a neodymium magnet, which is the strongest type of permanent magnet, and I washed it 4 times and strained fluid in at the coffee filter.
I want to reiterate that the picture of the coated magnet makes the particles look larger than they are because the magnetic field is making them stand up on one another. This wear metal is so fine I don't think the coffee filter would have even caught it...finer than graphite lubricating power.
I'll post my Blackstone results when I get them.
Post the early analyses too. That would help. Absolute numbers (PPM) of metals are very helpful for an internal wear evaluation.
BTW, I learned how to inspect filters from a lab with 110 operating test cells. They cut open, remove filter paper, then laid it on a 1/2 thick layer of paper towels. Then wet with stansiol solvent (i use mineral spirits) then lay a a big piece of steel on the top to press into the towel. Come back a couple of hours later and inspect.
I do much the same, use Viva paper towels on top and bottom, 5 lbs of 1/2 steel bars, and inspect the next day, it is bone dry and shows shiny particles easily.
All of this above is correlated with oil analysis results.
Your method is interesting, and not to imply it is wrong.
To OP: Any repeated high Fe content in well stirred oil would be a call for deeper inspection. It could be a result of fine rust formed on gears and now is continually eating into the teeth. That fine material is an abrasive slurry to oil passages.
Any field opening of the engine can yield a jump in wear metals for a period.
A particle size analysis using ISO terminology would be helpful if diagnosis needs to continue. Hopefully, it will all diminish with regular use - continue your short oil change periods to establish a trend sooner.
