VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Remove cured pro seal (https://vansairforce.net/community/showthread.php?t=177988)
bizpilot 12-22-2019 06:47 PM
Anybody know what to use to remove unwanted cured pro seal?
jcarne 12-22-2019 06:50 PM
Depending on what your removing it from, Vans sells a gel that works quite well at removing it.
N941WR 12-22-2019 07:05 PM
Where is it?
If it is on your tanks, don't use any chemicals as you run the risk of it penetrating the Proseal on the rivets.
Sand it off.
Piper J3 12-22-2019 11:25 PM
I used wire wheel on Dremel tool.
rv8ch 12-22-2019 11:57 PM
proseal cutter
I have not used it, but when this was discussed a while back, I decided to buy one of these just in case.
https://www.3m.com/3M/en_US/company-...3193699&rt=rud
And a set of hard plastic scrapers, which have come in handy dozens of times.
MED 12-23-2019 04:31 AM
Phenolic and plastic scrapers work well. The Yard has inexpensive phenolic scrapers and ACS has nice plastic ones. Polygone goo works best on residue.
flysrv10 12-23-2019 07:32 AM
Serrated plastic knife and lacquer thinner.
bizpilot 12-23-2019 01:19 PM
It’s for the rudder trailing edge. I put the wedge in backwards ��
N941WR 12-23-2019 08:53 PM
Do NOT use lacquer thinner or any other solvent. It can penetrate the Proseal around your rivets. And while it might not cause paint blisters now, in a coupled of years it probably will.
wilddog 12-24-2019 04:02 AM
Try a heat gun to soften it then slip a plastic knife between the TE and skin.
rvflyerUk 01-08-2020 03:57 AM
Removing proseal
Hi,
I needed to do this for a leaky tank baffle; I haven't tried the Vans stuff but if you can obtain some 'Skyrestore' from https://www.socomore.com ? Surface preparation ? Sealant removal
This does the job, although you need several applications to remove a little at a time- it's quite time consuming.
Southern Pete 01-08-2020 06:34 AM
The only chemical that will touch cured Proseal is MEK. It is horrible, nasty stuff, be very careful. Use a mask and gloves. Cut off as much as possible then use MEK on a rag to rub off the residue, use it sparingly.
RyanS 01-08-2020 06:49 AM
PolyGone Gel
For reference, here's a link to the PolyGone Gel 310-AG Polysulfide Stripper sold by Van's.
https://shop.vansaircraft.com/cgi-bi...oduct=polygone
rvflyerUk 01-08-2020 06:49 AM
Remove with MEK
Hi,
I can't agree, it will take forever !!
