VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Remove cured pro seal (https://vansairforce.net/community/showthread.php?t=177988)
rvflyerUk 01-08-2020 03:57 AM
Removing proseal
Hi,
I needed to do this for a leaky tank baffle; I haven't tried the Vans stuff but if you can obtain some 'Skyrestore' from https://www.socomore.com ? Surface preparation ? Sealant removal
This does the job, although you need several applications to remove a little at a time- it's quite time consuming.
Southern Pete 01-08-2020 06:34 AM
The only chemical that will touch cured Proseal is MEK. It is horrible, nasty stuff, be very careful. Use a mask and gloves. Cut off as much as possible then use MEK on a rag to rub off the residue, use it sparingly.
RyanS 01-08-2020 06:49 AM
PolyGone Gel
For reference, here's a link to the PolyGone Gel 310-AG Polysulfide Stripper sold by Van's.
https://shop.vansaircraft.com/cgi-bi...oduct=polygone
rvflyerUk 01-08-2020 06:49 AM
Remove with MEK
Hi,
I can't agree, it will take forever !!
