VAF Forums
-   RV-3 (https://vansairforce.net/community/forumdisplay.php?f=10)
-   -   RV3B Wings (https://vansairforce.net/community/showthread.php?t=177648)
Jonthor 12-11-2019 03:43 PM
Hi Steve
Thanks for the advice I might do that to ease my mind.
If anyone knows anyone that wants to sell a QB wing kit for any reason I would appreciate if you would let me know, I would like to buy one to be able to move along to save time and be at ease.
best regards
Jon Thor
WillG 12-12-2019 03:50 PM
Jon
Leave the fuselage rear spar bulkhead loose, until you have the wings
done - then you can confirm location for that bulkhead.
A lot can be finished on the fuselage with that bulkhead loose.
MWG
Jonthor 12-12-2019 05:17 PM
Hi Will
Thanks for the advice, much appreciated.
Best regards
Jon Thor
steve lenne 12-12-2019 07:38 PM
Rear wing spar fuse attach
Fixing the main spar bulk head should not be any issue but the rear spar attach is another issue . I Know of one fella who left the rear spar attach bar loose until the wings were attached. My main concern was edge distance when drilling the rear spar to the fuse bar. I used a wider bar than what was in the kit to avoid any problems with edge distance when the wings were fitted.
Steve
Rv3b built & flying
WillG 12-13-2019 08:43 AM
I agree, i did not use the plans call out bar height dimension for the rear spar.
I ordered what was needed to maintain attach bolt edge distance.
mwg
Bagger 12-15-2019 08:37 PM
RV3B wings
I purchased two sets of quick build wings and fuselages from Loyd Remus and I am very pleased with his work and ethics. His phone is 719 3395729.
My half of the purchase has now 120 hours with one problem..... Flat tyre.
Jonthor 12-16-2019 09:44 AM
Hi
So you are saaying that Mr Remus builds wings for RV builders to facilitate those who want to save time on their projects?
