VAF Forums
-   Glass Cockpit (https://vansairforce.net/community/forumdisplay.php?f=35)
-   -   G3X flap and trim display problem (https://vansairforce.net/community/showthread.php?t=177566)
caapt 12-08-2019 06:53 PM
I have a G3X Touch display with Vertical power system. My flaps, Pitch and roll trims all work correctly. The flap and pitch trim indicators do not show the correct position and bounce up and down continusly with no control surface movement. The roll trim indicator is frozen in the center position. Any ideas?
pilot2512 12-08-2019 07:07 PM
Can you confirm the serial data between the VP-X and the G3X are working? Also check on the VPX that J10 pin 9 and J12 pin 4 are grounded.
Jay
ssonixx 12-08-2019 08:49 PM
Calibration
Are they calibrated and are you using the right inputs? Sometimes the simple things are the culprit.
caapt 12-11-2019 09:16 PM
Problem Solved
Working with Josh at stein air we discovered that an incompatibility between the garmin config and the VPX config. I deleted the Garmin config for flaps and pitch trim and immediately, everything worked. Thanks Josh
Roo747 05-08-2020 06:09 AM
How to delete Garmin config?
I am having a similar problem and wondered how you delete the garmin config? I'll try that.
Also, anyone running the G3X, I was using a SD card for the last year and recently reformatted it. (FAT 32) now it says card unreadable, format to FAT 32.
Anyone run into this?
g3xpert 05-11-2020 03:39 PM
G3X Trim Position
When using the VP-X for trim position, you need to disable any General Purpose inputs that may be configured for trim position on the GEA 24. This can be done powering the G3X up in configuration mode, touching Engine & Airframe, and reviewing your settings for the GP inputs. If there are any set as a Trim position input, you will want to disable them.
Justin
rocketman1988 05-11-2020 05:00 PM
Yep
I had to do the same thing.
A question for the G3Xpert...
Can the GP 1 and GP 2 inputs now be used as a discrete (using the 5k resistor) or do they need to remain in None (disabled)?
g3xpert 05-14-2020 09:24 AM
GP Input Discrete
If you are not using GP1 or 2 for any other purpose, yes they can be used as a discrete input.
Justin
rocketman1988 05-14-2020 01:38 PM
Discretes
Thanks for that!
More specifically, as long as the configuration is NOT elevator or aileron trim in the G3X configuration page, the GP 1 and GP 2 are free to be used for something else, correct?
Roo747 06-27-2020 09:25 AM
Trim Flag
So I deleted the GP Trim settings under the GEA 24 tab in the configuration mode, however, i'm still getting a Red Trim flag on the EFIS although the trim system is working fine with position indications coming from the VPX on the EFIS showing correctly.
