VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   Spinner Mounting Question (https://vansairforce.net/community/showthread.php?t=177480)
Stockmanreef 12-05-2019 05:17 PM
I read the plans and maybe (as usual) I missed something and there is no point where you need to line the spinner up to ensure there is no wobble. Feedback from the mothership also indicated that you don't have to do anything special to get the spinner lined up. I guess you just make sure that the spinner is pushed in tight and the combination of the front and back spinner plate will make the spinner fit perfectly without wobble.
So does the spinner just line up perfectly without wobble?
In the older planes (6, 6, and 8), there is a method to get the spinner lined up using a pencil and rotating the prop.
Are most people putting on the spinner and lining it up by rotating the prop, then putting on the cowling? Or using the method in the plans.
Don E 12-05-2019 07:35 PM
This being my first offense...
...and not knowing any better, I followed the plan instructions. Worked out perfectly.
Stockmanreef 12-05-2019 08:19 PM
With that in mind, I think that I could tape or temporarily screw the spinner in place and do the cowling without rotating the prop. That would be nice, since it would leave the engine pickled. Of course, I would have to mount the prop at the angle the flange is now and not horizontal. That could be interesting.
thanks
Bavafa 12-05-2019 09:21 PM
Ken,
You really don't need the spinner fitted to do the cowl but you will need the back plate attached to the prop.
As for fitting the spinner, I went out of my way by using a dial indicator to make sure it comes out perfect and it did but I really had very little movement for changes so I think if I had just done without the dial indicator, it still would have come out great.
Hope this helps.
Stockmanreef 12-17-2019 07:33 PM
I put the spinner in place temporarily and I still have a question.
I see that the last thing you do is sand the back edge of the spinner flush with the back edge of the spinner back plate. But should the back edge of the spinner line up with the starter ring gear like the spinner plate does prior to drilling? In other words, is the spinner cut well enough that if you put is flat surface that the tip of the nose is dead center.
My spinner is gray, so it is difficult to tell if the spinner is pushed up against the front spinner plate well.
TimO 12-17-2019 08:37 PM
I pulled the plugs out of the engine and spun the propeller with a marker on a stand, so that I could get the tip of the spinner to spin in a nice non-wobbling dot that made the smallest center possible. I don't t know that I'd trust the fiberglass mold to be perfect if you just align it on the back side.
mturnerb 12-17-2019 08:58 PM
I did something similar, then put a laser on the dot while I drilled the spinner.
rvator10 12-18-2019 06:39 AM
on a side note:
Vans pre-mark?s the propeller blade cuts on the spinner, these marks are too generous and leaves a large gap with the propeller, did anyone else get caught up with this like I did :mad:, maybe time for a new spinner and starting over.
lr172 12-18-2019 10:02 AM
Originally Posted by rvator10 (Post 1393633)
on a side note:
I didn't think I could trust them. Got a template direct from Hartzell and used that as a guide. It was very close, but I still cut small and worked my way out to correct size.
Larry
mturnerb 12-18-2019 12:00 PM
on a side note:
I used their marks and ended up adjusting some to give good clearance through full prop movement. By the time I put the gap filler back in (the small fiberglass pieces permanently mounted to spinner backplate), the gap isn't an issue for me.
