EFI engine shutdown
Is there a preferred method for shutting down an EFI Lycoming? Just turn off the master like on a car, or shut the fuel pump off?
Obviously both will shut the engine down. I was interested because of a wiring logic I would like to use. |
I have been using EFII for 4 years and 800 hours now in my RV10. Shutting down starts with shutting both ECU units, then master.
engine should run with master contactor open
Thanks for the responses. |
I have mine set up so that I can toggle an emergency bus switch which will give power to the essential buss that the engine runs on. So on a normal shutdown I just turn the master off and the engine dies. If I engage the emergency bus switch first, the engine will keep running with the master off.
You can kill coil or injector power or shut off the pumps.
Is there a reason you can't just pull the mixture to cutoff first?
Any downside to just killing the fuel pump first?
| All times are GMT -6. The time now is 10:16 PM. |
