VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Pro Seal Substitute (https://vansairforce.net/community/showthread.php?t=177284)
Jetmart 11-27-2019 04:43 PM
Pro Seal Substitute
Has anyone used JB Weld or some type of Gorilla glue instead of pro seal for attaching the foam ribs in the trim tab and elevator?
I used JB Weld on another project and it was very nice to work with versus pro seal.
PaulvS 11-27-2019 05:40 PM
Silicone
I used neutral cure silicone, as advised by my inspector.
GeoffP 11-27-2019 11:18 PM
3M VHB tape
I used the VHB double sided tape that Van's sell, and they also mention (somewhere) that this product is a substitute for pro-seal in the applications you talk about.
Jetmart 11-28-2019 05:12 AM
Thanks I have some for the trailing edge but did not realize it is a substitute for the foam ribs.
rvbuilder2002 11-28-2019 08:13 AM
I am pretty sure the VHB tape has never been approved for installing the foam
ribs.
I would strongly recommend against it.
I wouldn't recommend using silicone adheasive either.
David Paule 11-28-2019 08:28 AM
Also, JB Weld is fairly brittle, so I wouldn't use it.
Stick with the plans and it'll work out best.
Dave
RV6_flyer 11-28-2019 09:08 AM
Pro Seal is a brand name of Mil Spec Polysulfide. Any product that meets the same Mil Spec would be good.
I would not recommend any substitute that does not meet the same Mil Spec especially in any moving aircraft surface.
JDA_BTR 11-28-2019 10:36 AM
I keep a quart kit in the freezer and thaw it out for use. Mix it on cheap throwaway dollar store cutting board plastic with a bondo squeegee. I?ll have new stuff for tanks but for everything else this works great.
rockwoodrv9 11-28-2019 11:36 AM
I have been using hotel type card keys for years to spread epoxy, bondo, and pro seal. They work great.
GeoffP 11-28-2019 03:50 PM
I think you're right
ribs.
Looking back through the plans & store info on the VHB tape it isn't mentioned specifically for the trim tab ribs, just as a substitute for pro-seal on the rudder or elevator trailing edges. I must've just assumed at the time it would be OK. As it is I was going to do another trim tab (mainly because I wasn't 100% happy with the trailing edge), and as I'm in the middle of building tanks I've got pro-seal everywhere so a little more won't hurt.
