As some of the thread photos have gone MIA, you can see some info and photos on our "Dave Page" here: http://www.sdsefi.com/dave.htm |
I often fly a T182T which I also maintain. Typically out of the initial climb I dial back to 2000 RPM 28" and lean for 1600 TIT ~12.3 GPH. I just keep that power setting after leveling off. Adjust cowl flaps as necessary to keep it cool. Cowl flaps open I typically see 380 CHT in climb. With the cool temps now it will cruise around 340 CHT with the cowl flaps closed. Heat on this airplane is entirely manageable. In reality the turbo simplifies operations as you can run one power setting in climb and cruise.
Would love to have this type of turbo setup in an RV but it would have to be in one of the longer-winged airplanes (-9, -10, etc.) as the high aspect ratio wing works better for higher altitude ops. |
If the prop was maximized for that 2000 rpm wouldn?t it do the same. Like gearing in a car. One thing I?ve learned w Pontiacs is they like to be maximized for torque and at a lower RPM can?t build them like a Chevy they won?t live. So if he made the same Torque at a lower RpM and proped it accordingly like a 308 gear as opposed to a 4.11 gear wouldn?t that make the same amount of work? and therefore propel The plane the same speed at a lower rpm? |
Not to sounds cocky but I beat lots of guys at the track that thought money could win races. Loved doing that more than anything else. 😃👍 My favorite saying is: Knowledge is power! |
Automotive experience does not automatically translate to aviation. Specifically, the systems used for the highly variable speed automotive engines are simply dead weight for essentially constant speed aviation engines. Addition of those items probably won't kill you, but your craft will be heavier and more unnecessarily complex than mine at the same engine output. Here's an idea. How about listening to the advice being given rather than constantly arguing with it. Ask why rather than state yeah but I.... |
Here's a reference: https://generalaviationnews.com/2009...-deck-engines/ |
All this talk about more speed, etc, turbos. Anybody every think about flutter? One of my buddies is a DAR for structures and for flutter, and he tells me that flutter excitation comes from indicated airspeed but damping comes from true airspeed... or something like that. If you do even a little research, you can find some gliders, for example, that show redline airspeed (indicated) decreasing with altitude. Van's has posted on this in the past.
I never understood why folks would want to take the wonderful RV handling and then fly straight and level for hours on end. And if you want a faster airplane, go buy one. All this stuff about world's fastest RV whatever reminds me of that line from a W.C.Fields movie where he's a carnival huckster, inducing folks to come see "the world's largest midget." |
yep...
"...if you want a faster airplane, go buy one..."
As nice as the RV aircraft are, they aren't the fastest out there. It is great to experiment but if you want a really fast aircraft, it is probably better to look elsewhere than try and make the RV something it is not... ...and you are correct about flutter; it isn't anything to play with...and it doesn't matter how "good" you think you are... Funny that this would come up again just a day after the anniversary of the Tacoma Narrows Bridge incident... |
| All times are GMT -6. The time now is 09:51 PM. |
