Garmin G5 and Aera 660
Greetings Garmin Exprt;
The is probable a dumb question from a novice flat panel guy. (Experience round dial guy) I am installing a single G5 (no auto-pilot) and an Aera 660 in a non-RV experimental. I had a harness built up to connect the G5 to a Garmin GMU-11 Magnetometer. The harness came with an RS-232 pig tailed off the G5. The GMU-11 communicate to the G5 thru a series of twisted wires called the CAN bus. So, I am thinking the RS-232 cable is for a future gizmo. What would be the benefit to connect the G5 to the Aera 660 dock via the RS-232 cable? Does the G5 allow me to select between an HSI and PFD view? Maybe the 660 could drive a Course Deviation Indicator on the HSI view? Help me understand. |
Yes, as David correctly pointed out, an Aera 660/795/796 can provide lateral and vertical (VNAV) guidance to a single or dual G5 installation (with or without autopilot servos) over RS-232.
| All times are GMT -6. The time now is 05:30 PM. |
