0-360 fuel injection conversion
Hi all ... wondering if anyone has experience with 0-360A1A conversion to fuel injection with PRECISION AIRMOTIVE SILVER HAWKE EX system ?
Buying the FI setup from another forum member complete but wondering if I will need a different sump ? ... in RV4 so hoping to get away with minimal or no ( ) major cowling mods. Many thanks in advance. Cherrs. Stew |
The injector body is shorter than the carb on an O-360, so a spacer (I believe around 0.5") will be required to but the mouth of the injector in the same place as the carb so your current induction set up can be used. Think about if you require regular or reversed mixture rotation. It can be changed by sending the injector body to Precision. Don't forget a new electric fuel pump and fuel pressure sender (which may have to be re-positioned).
| All times are GMT -6. The time now is 03:00 PM. |
