Overvoltage Warning
Started the plane today and got an overvoltage warning on my GRT Mini. Voltage was reading 14.4 on the gage, which is a bit higher than normal. Is this an indication of a failing voltage regulator (I have a Nippondenso alternator with built in regulator)? I can probably increase the warning parameters on the GRT, but am I risking damage to any of my avionics or electrical? What?s a ?safe? upper limit?
Terry, CFI RV9A N323TP |
The sky is falling, the sky is falling!
Charlie |
Thanks Charlie!
I?ll reset tomorrow. I?m doing my condition inspection and probably let the battery run down too much while testing things. Never saw the warning before on my EFIS, but it was the end of a long day and brain and body were running on reserve. Appreciate the details in your response.
Terry |
B&C's over voltage warning kit has their gizmo preset for 15.2Vdc. The failure I saw was an occasional flicker of the over-volts warning lamp, gradually progressing nearly full time. Buss voltage was 15.4 volts at that point. Replaced the external rectifier/regulator on my 2-wire system and all is good since.
Source : https://www.odysseybattery.com/docum..._Procedure.pdf |
16 volts is the normal upper limit. Most modern avionics can support up to 32 volts, and temporary excursions above that for very short periods of time (<1 sec).
Overvoltage conditions need to be rectified within milliseconds, so it's best, IMO, to have some sort of OV protection system that can shut down the alternator much faster than a human. Your OV alarm is usually a popped alternator field breaker. Low voltage is a different beast, and is not nearly as time-critical. |
I know automotive voltage regulators regulate the voltage based on outside temperature.
The colder it is, the higher the charge voltage can be for a lead-acid battery. So the regulators will raise the voltage when it's cold. Airplane regulators probably do the same thing. |
Please clarify
https://bandc.com/wp-content/uploads...anual_revC.pdf On page six it states: " the integrated over-voltage protection function is set at a non-adjustable 16.0 volts plus or minus 0.2 volts on the LR 3 C - 14." On the top of this same page it also states that this voltage voltage regulator comes preset to a charging limit of 14.4 volts. However the user can adjust the maximum charging voltage as he or she sees fit. Perhaps we are referring to two different B&C products??? Since you mentioned rectifier regulator I suspect that you are dealing with either a model SD - 8 or model SD - 20 Dynamo style backup alternator system. Charlie |
Not quite
Some modern automotive and marine charging systems have the voltage regulator built into the PCM ( powertrain control module AKA engine computer). These systems can monitor the temperature of the alternator and also of the battery. They are able to adjust the charging voltage to compensate for either of these items starting to overheat. As you also mentioned they can raise the charging voltage when the temperatures are low. This is being discussed on another thread here. I believe the title of the thread is PlanePower versus B & C. http://www.vansairforce.com/communit...d.php?t=176462 Charlie |
| All times are GMT -6. The time now is 12:17 PM. |
