On start - Weird EGT on cylinder 4
The other day when I started the plane #4 EGT wasn't rising, per the engine log it was lowering to 285 for about a min. One I started taxing it started then spiked to 1305 and then over the next minute normalized in line with the other 5 cylinders.
Flew normal for the next hour and looking at the log nothing else erratic. Could this be a plug or lose probe or something entirely different? |
Either the cylinder wasn't firing and the probe had an issue. It is possible that the plugs fouled from being overly rich during the start and took a minute to clear up before they could begin firing. Probe doesn't need to be tight to work properly. It is not grounded via it's body. Sticking valve could do it as well, but not likely on a new engine and uncommon on dead cold engine.
Larry |
Thanks, wrapped up my oil change at lunch. Started right up and all temps were normal. It is possible that I pumped to my gas in for a cold start.
Larry |
EGT Probe Replacement
Just went through the same thing. In this case it was the probe. I swapped the probe from number four to number two cylinder. It happened again indicating cylinder four was faulty when in fact the probe was in cylinder two. Before I got a new probe, the probe would work properly for awhile and then fault. Common fault was at start the EGT temp would go through the roof.
A cause for missing on cold start, especially on new or overhauled engines, is
that with cold oil and tight clearance the oil pressure can spike as high as 150 lbs holding the lifter up until warm oil can get to it. If you would like to check this, attach a pressure gauge to the oil galley at the front of the engine. the pressure may not show on the planes instrument due to the lag in the capillary tube, you may be surprised. |
| All times are GMT -6. The time now is 10:52 PM. |
