VAF Forums
-   -   TruTrak ?NO GPS? (https://vansairforce.net/community/showthread.php?t=175949)
Jetj01 10-10-2019 10:59 PM
TruTrak ?NO GPS?
Hello Trutrak experts!
As you may know it?s kind of hard right now getting ?tech support? from Trutrak what with their acquisition by King. We?ve run into a problem with our ?new install? Vision 385. We CAN NOT get the Trutrak to get a GPS position from the Garmin 375. Partial problem is the 375 is new so NO Trutrak literature covers it.
The 375 connects thru a Garmin Gad29B to a Garmin G5. We ARE connected to the Trutrak in that we can get the Trutrak to ?steer? using the G5 heading bug. Furthermore, the G5 works/navigates from the Garmin 375 but we CAN NOT get a GPS fix on the Trutrak from the Garmin 375. Therefore no GPSS steering.
The manual says that means we have a ?configuration issue? and/or a pin out/wiring issue. We have triple checked the wiring. Is it configuration?
Any EXPERT help appreciated to get a GPS fix on the Trutrak from the 375.
Thanks in advance!
Jj
Ted RV8 10-11-2019 03:32 AM
Do you have the baud rate set the same for each unit?
Capt 10-11-2019 05:09 AM
Check the serial ports assignment in the TT itself (not hard wiring) otherwise the TT won't be able to talk to a GPS.
