Am I missing anything on this Garmin GNS-430W pinout?
Hello everyone, I am trying to finalize the pinout on my Garmin 430W tray and would really appreciate it if someone with more experience could review the items I crossed out in green to see if there are in fact some that shouldn't be corssed out. I think I have it down but I don't know what I don't know. I also am thinking to myself "dang, there is a lot of open spots in them connectors". I would really appreciate it, even if you could direct me with where to go for more info!
P.S. I read the manual, it doesn't give detailed descriptions for most of this stuff. Or descriptions that a noob like myself can understand sometimes:) Most of it was based off of looking at the drawings. Also attached is my panel. All Dynon through an ARINC-429. Com is a GTR-200 and audio panel is a GMA-245. Mega thanks in advance! 4001-1 by Jereme Carne, on Flickr 4001-2 by Jereme Carne, on Flickr 4002 by Jereme Carne, on Flickr 4006 by Jereme Carne, on Flickr FINAL PANEL by Jereme Carne, on Flickr |
I always bring out the 232 ports for various uses, the dynon will need one and so will ads-b.
As Walt said, you’ll need them for the Dynon, maybe ADSB-out, maybe altitude for your transponder. I do not under stand your label, ‘RS232 out to ARINC’ Do you want one control for lighting levels on all avionics? If so brimg out the dimmer lines (auto dim works okay, imho). For IFR, the 430’s annunciations are supposed to be within a certain distance from the AI/EFIS. If you need remote annunciation to meet this, bring out the annunciation lines. Edit. You know your final panel does not show a 430W? Edit again. Thanks for the answer (see post below) |
1 by Jereme Carne, on FlickrI was planning on just using the auto dimming feature of all the devices but perhaps it might not be a bad idea to bring them lines out for future changes if wanted. Also looks like it is well within the field of view requirements for annunciation. I will double check though. Thanks for the great feedback! Quote:
Looks good Jereme. I checked my notes and the only difference I noted was on connector P1001/4001 I tied pin 56 to arinc pin 3.
p1001/4001 pin 58 has a 1.21kohm resistor tied to pin 3 on the sv-xpndr-261 Travis |
Apparently I wired it that way because I only installed the GPS250. Not sure if it makes any difference since you have the 2020
Travis |
I took the RS232 wires to an accessible D connector. Makes additions and changes easier. Mount it where you can get to it with the EFIS out of the panel or other accessible place. I also took the outputs to a couple of pins as they can be paralleled to other devices.
| All times are GMT -6. The time now is 11:25 AM. |
