VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: Hammering 3/16" spar rivets (https://vansairforce.net/community/showthread.php?t=17570)
WSBuilder 05-07-2007 08:17 AM
Came close to destroying a spar with the hammer when it slipped off the C-frame set. I bent the spar flange a little but was easily fixed. Whew! Turns out the anvil base screws had backed out on my new Avery unit and the loose set up became unstable. Lesson learned: check those anvil bolts before each use. Also, lay a sheet of plywood or similar across the spar to prevent bashing your parts!
sprucemoose 05-07-2007 12:44 PM
And, if you set the C-frame on a piece of plywood (to save your concrete floor) make sure you don't leave the c-frame in one spot for too long. You will pound grooves into the wood, and the c-frame will get unstable in these grooves, and bad rivets can result, or worse. Sort of like holding a bucking bar very loosely against the rivet.
John_RV4 05-07-2007 02:15 PM
Hammer ? Spar ? Waddhe say ??
You guys realize that 99.9% of the people reading this forum have no idea what you're talking about :-).
Now, get back over to the RV4 forum. We're going to mine some Bauxite at 5:00 today :-). Don't miss out....
John
WSBuilder 05-07-2007 03:53 PM
John
You're right, John. I'll be over as soon as I club a woman and drag her back to the cave for a mastadon dinner.
petehowell 05-07-2007 09:38 PM
This thread made me laugh!
As prepunched QB -9A builder, I know I am not worthy. Van's actually had the gall to make me mark and drill a hole once.......never again
WSBuilder 05-08-2007 09:45 AM
Bragging or Complaining?
The contrast between the old and the new is pretty big. At first I was excited about the fact that new -4's have pre-punched wing skins (see? I'm glad I procrastinated 22 years after my empennage). Now I'm finding that without pre-punched matching parts it's like giving Viagra to a eunuch. I think it makes it even harder! :eek: But I'm sure I can still rise to the occasion!
Sam Buchanan 05-08-2007 01:24 PM
Regarding setting spar rivets:
Ahh, yes......a blast from the past. I fondly recall those days long ago when the feeling of immense satisfaction washed over me as I gazed at the beautifully set rivets in the handmade spar of my RV-6 Classic (or maybe I was just goofy after kneeling on the shop floor and swinging the three-pound sledge too long...).
http://thervjournal.com/spar_log.html
I agree the prepunched wing skins and unpunched sub-structure adds to the layout time, but it does result in nice, straight rivet lines. :)
WSBuilder 05-08-2007 02:04 PM
My Hero
Sam,
I had a print out of your spar log open on my work table all the while. I just don't have intrepid explorer genes in me, so thanks for being there before me!
GAHco 05-08-2007 03:53 PM
I knew
I am an RV6 slow build (98) and I know what he was talking about, thats why I borrowed a big nasty squeezer.
I felt I would have more control and get better results.
http://www.gen-aircraft-hardware.com...plane_proj.asp
JonJay 05-08-2007 04:32 PM
6 Classic, pounding away....
I borrowed a squeezer directly from Van's when they where in North Plains. They would let local builders borrow it. However, it was so torn up it did not work when I tried using it. So, pound away in my Cframe. I was surprised how well it worked and how well the Cframe held up.
