Rivet heads?
It has been over 12 yrs since I test fit my weldments but I had an interference with the universal head rivets in the pre-made center section and the clearance hole in the weldments. The center section was not installed when I noticed the interference.
Had to add to open up the weldment clearance holes to clear the heads. |
Fitting them mounts seemed like it would be a 30 min job. I was so mad when it took 5 hours. haha Way it goes some times. |
Thanks. I made sure all the hole for rivet heads were clear when I did my first fitting. It also took me 5 hours to do this!
The manual says to shim if over 1/16", I just don't know if it's acceptable to shim for 1/8". Hopefully, this doesn't change too much of the fit because thinking it was good, I drilled the other support arms. These things are like $450 a piece! |
Can you see/tell if anything is causing interference? I know it's hard to see back there. You may get a feeler like a chip clearing tool and see if you can feel where it is hitting. (assuming you are 100% sure the rivets are clear) |
| All times are GMT -6. The time now is 02:34 PM. |
