VAF Forums
-   Rocket (https://vansairforce.net/community/forumdisplay.php?f=80)
-   -   New Owner fresh air vent question (https://vansairforce.net/community/showthread.php?t=175185)
cduster 09-13-2019 02:46 PM
New Owner cockpit temp question
Hello guys and gals, I recently picked up a HRII (N86WR) and after a few short flights have noticed quite a bit of heat pushing back from the firewall. The problem is noticeably more pronounced at lower speeds. Does anyone insulate the firewall, or have any other ideas?
David Paule 09-13-2019 06:09 PM
There has been some serious discussion about this. Dan Horton did some testing and developed an excellent, thoughtful method of insulating the firewall. The insulation goes on the FRONT of the firewall:
http://www.vansairforce.com/communit...43&postcount=5
I came up with the idea if using titanium foil instead of stainless, and you can read one builder's experience and a discussion of that here:
http://www.vansairforce.com/communit...light=firewall
Dave
jcarne 09-13-2019 06:13 PM
I also documented a slightly different titanium approach if your interested in reading. Start at the last post on the page.
http://www.vansairforce.com/communit...149050&page=32
cduster 09-14-2019 06:17 AM
Wow, you fellows are doing some amazing work.
