Lycoming 6 cylinder 24volt electronic ignition system???
I was disappointed to find out yesterday the SDS CPI-2 Dual Electronic Ignition system I WAS going to buy yesterday DID NOT have a 24 volt system option ☹️ I was very impressed with their product but DO NOT want the added complexity of a step down to 12 volt. Is there a GREAT option for dual electronic ignition for 24 volt systems for my AEIO Lycoming 540 with single drive dual magnetos with CS prop?
Thank you for ANY inputs👍 |
Surefly's operating voltage range is 8.5 to 30 VDC.
Multiple base timing choices, with or without advance. https://docs.wixstatic.com/ugd/712b8...762579e72a.pdf Per their OSH press announcement, Lycoming will soon (?) release a Lycoming-branded version with a proprietary advance map. |
Thanks Dan!
They appear to be a mGneto replacement concept. Unfortunately with the single drive dual magneto system, won?t work. I?d like to eliminate my system completely. Jj |
Are you locked in to a 24 V battery? My B&C 100-1 12V battery cranks the **** out of my high compression O-290-D2. They advertise:
I may be able to help
Check your PM,s
The 4-cyl Dual-Mag engines have a pressurized oil port in the bore which supports the mag gear on the crankcase side. I don't know if the 6-cyl Dual-Mag engines do too, but if they do, you'll need to add a dummy shaft to the mag coverplate to block that oil hole.
I'd just step down to 12v. Not hard, and the circuitry is well proven.
What about using a TCW backup battery as an additional 24v -> 12v buffer? It might do the stop down itself, but putting that in with the mix should be easy. |
If you decide to use a step down you have to make sure it is rated for the required current you'll need plus a buffer. Another option is to run the ignition on a separate 14 volt system. Running two 12 volt batteries for 24 volts and taping one for 12 volts, charging both with 24 volt alt. EZ
Anyone with Pix? We have a cover plate with dummy shaft, (here are 3 different bore sizes BTW) but don't know if it's needed. We have a recommended 30 amp 28 to 14V power supply that people have used for our EFI systems, pretty light and compact. |
| All times are GMT -6. The time now is 12:36 PM. |
