VAF Forums
-   Flight Testing (https://vansairforce.net/community/forumdisplay.php?f=70)
-   -   RV-7 vs RV-8 aileron response (https://vansairforce.net/community/showthread.php?t=17448)
rv72004 05-02-2007 08:40 AM
I flew the 8 a little bit the other day and it seemed to me the ailerons are lighter and roll quicker than the 7 . As this is the first in a 8 but have quite a bit of time in a 7 , I am still deliberating if it was my imagination.
I must say it really felt nicer than my 7. Was I imagining it ?
EJ
MikeJ 7A 05-02-2007 09:17 AM
Center of mass
With two folks sitting in tandem (vs side by side) the center of mass will be closer to the roll axis. Seems like it should take less force to start/stop a roll.
MikeJ
Ironflight 05-02-2007 09:27 AM
I can't speak to a 7, but I have flown two different -6's in the past month, and was actually surprised at how light an nimble they felt in roll compared to my -8. Not that the -8 is heavy mind you....;)
n5lp 05-02-2007 09:30 AM
Originally Posted by rv72004
I flew the 8 a little bit the other day and it seemed to me the ailerons are lighter and roll quicker than the 7 ...
I wonder if the stick lengths are the same? A shorter stick is going to require higher forces.
dan 05-02-2007 10:39 AM
Trailing edge radius on the aileron would probably have a bigger effect than probably anything else, right?
Norman CYYJ 05-02-2007 01:51 PM
I agree with Dan.
L.Adamson 05-02-2007 06:16 PM
Some trailing edges on dedicated aerobatic aircraft, are squared off. As if you ran a saw, and cut the last inch off.
L.Adamson
Scott Will 05-02-2007 06:24 PM
This isn't the 7 vs 8 comparison you were looking for ... but I agree with Paul.
When I took my 7A up for the first time after transitioning a week earlier in Pierre's 6A, I thought... WOW! This thing is a whole lot slower in roll! The stick forces to me are a whole lot lighter, especially in roll, when flying the 6A. Perhaps it's because of the slightly shorter wing?
pierre smith 05-03-2007 07:08 AM
Ahem...ahem...
Billy Waters had a 6 and now flies an 8. He has often told me that the 6 was a much better flier. BTW, I didn't shorten my stick any. The Van's pistol grips are at the same height as the original stick. Experienced RV fliers will, to a man, tell you that the -4 is the best flier of the bunch.
Thanks, Scott,
rvpilot 05-03-2007 07:31 AM
Yep!
Paul confirmed it, the -6A I had felt much quicker in roll than my -8. Although , if you get the CG back in the -8 by loading the rear, it helps the stick forces considerably. I can imagine that the -7 would be about like an -8 which is aft loaded. While still a great flying airplane, not quite as quick as a -6.
Kahana, you've flown all three, comments??
