VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   Electric fuel pump-Fuel Injection (https://vansairforce.net/community/showthread.php?t=17415)
gmkonrad 04-30-2007 06:52 PM
Has anyone installed and flown an electric fuel pump, on a IO-360 Lyc., other than the one Van's sells ? $800 for a Dukes is a bit steep also. Wondering if there might be a less expensive option .
Gary Konrad
RV-7 fuselage
N184JG 05-01-2007 05:26 AM
AFP PUMP
The pump vans sells is an Airflow Performance pump,if you buy an AFP F.I. the pump comes with it.I looked into buying a cheaper auto fuel pump with no luck. Its not just a pump it includes a check valve ,bypass,tubing and some fittings.I bought just the pump not the kit from Vans and the filter from Wicks then bought the F.I. from AFP the gave me credit for the the pump.Made my own mount very simple .
yakdriver 05-04-2007 09:03 AM
Gary, One thing about the Van's is you get all of the parts and pieces to mount it that makes it a no brainer to install. Don
frankh 05-04-2007 01:21 PM
I have two electric pumps from NAPA
One installed in each wingroot.
They are about $130 each. AFP will sell you their pressure relief valve, then you just need a throwaway inlet filter ($5)
Frank 7a
