Sensenich 72FM(85) with 9:1 pistons?
I have a friend that is in the last 10% stage and has a delima on whether or not his engine/prop combo is safe.
He has a fuel injected O-360 (stock 180hp) that has been upgraded with 9:1 pistons and he purchased a Sensenich 72FM (85) for use on his RV6A. After talking with a Sensenich rep, he was informed that this combo was not tested with this prop and he was on his own as to its reliability using this combo. Anyone else use this combination with any feedback? |
Brantel,
I'm not near my logbooks now. But, for about 300 hrs, I've been spinning the 72FM(85) on my RV-6. The engine is an injected, parallel valve 360, with 9.5:1 pistons, Lightspeed III, enhanced cam, GAMIs, Vetterman cross-over, blah, blah, blah. I'm still alive . . . for now :p Safety cables ala Reno racers are something I'm considering. ;) |
Thanks for the reply, anyone else?
The small amount of testing that I have been involved with, proved that changing ignition timing (variable timing with electronic ignition) or other physical things with the engine (compression, fuel delivery, etc.) does have a dynamic effect on the engine / prop relationship.
The problem is, like the Sensenich rep said, if the particular combination hasn't been tested then it is a gamble. It may be fine. It may be just barely outside of their exceptable vibration envelope. Or it may be extreemly outside of it. If it is unsafe, it may still take many hundreds of hours for it to show it self as a problem. These types of changes make an RV more experimental than others. Because of that fact, safety cables may be prudent. |
Please explain what safety cables are. I have a good guess but I really have no clue what they are.
BUT WHY DID YOU USE THAT PROP?
Thanks, Warren |
These types of failures were quite common in the early days of the O-200 powered Goodyear racers, as the builders would often cut down props, and then spin the engines up to around 4,000 rpm. These racers are required to have a cable that connects the engine to the airframe. If the engine mount fails, the engine will still be hanging from the forward fuselage, and the CG won't shift as far aft. You still have to do a difficult forced landing, but you at least have a controllable aircraft, and you should live if you fly it all the way to the ground. |
Modify engine re-test the PROP
Have you ever seen a shaker table with two different length rods with a weight at the end? The table shakes back and forth at a certain speed and the rods kind of swing back and forth (oscillate) gently; now you change the frequency the table moves and one of the rods starts going wild and the amplitude of the swing is huge, while the other rod is just bouncing back and forth like nothing has happened. As you change the freq the table moves back and forth again, the wild rod calms down and its back to normal for both. Now you change the freq again and the other rod goes wild and the first rod to go crazy is happy. That is harmonic or natural frequency. This is what happens with metal props. They are tuning forks. If you vibrate them just right they will oscillate wildly. This oscillation can get bigger and bigger and the bending and twisting can fatigue the prop very fast, like bending a paper clip back and forth. If you bend a clip just a little, a small deflection, you can go forever; however bend the clip just a little further back and forth, it will last only a short time. That is fatigue.
WE SHOULD PRESSURE SENSENICH TO DO TEST ON RV's WITH 360's AND EI. Its all about fatigue. These blades have some economic life, say 30,000 hours (just an example). In GA terms 30k hrs is infinite life right, because the prop will be worn down way before 30,000 hours. If fatigue life is more, than the part is not life limited. However a small change like EI or high compression could cut that down to 15,000 hours or even a 1000 hours, who KNOWS? You have to test. Going 8.5:1 to 9.0:1 with standard mags you are probably going to be OK (at your own risk). However add EI you are taking more risk. Again who knows 1,000 hours or 30,000 hours. Sensenich should do what Hartzell did, pony up and test at least one RV with EI. I say EI because that's a much more likely modification than HC pistons and may be as critical or more critical? Again who knows without test. Sensenich makes a prop with performance and value. If you're going fixed pitch it would be my choice. It is after all a design specific RV prop, not just a generic prop. It also is fast, low maintenance and very reasonably priced. I am a constant speed prop guy, but I admire the Sensenich. I love wood props for their beauty, light wight and low cost. The down side of ANY metal blade/ prop is it has to be tested for max safety. Metal props could be made to be fatigue or harmonic free if they made them thicker and heavier, but that would be a double whammy. It takes performance away (thin is good) and adds weight. So the engineers balance the performance, weight and fatigue. The up side of wood or wood/glass props is we know wood is a good natural damper of vibration and fatigue is not really a concern with wood and composites. However wood or wood/composite should be tested as well, but often they are not tested even on a stock engine, much less a modified engine. Do you think Catto did testing? Its still a question what MT has tested or not. Unlike Hartzell who has written documents, MT has not really said what they have tested, engine mod wise. I hear they have but have not seen it in writing. Most wood glass props will die due to impact damage, erosion or material degradation before fatigue. However if I was going with a radical engine, I would consider a composite prop. Since I don't have oodles of money I went with a stock 360/EI and a Hartzell that has been tested. At least I know the critical RPM's. On the plus side of wood, at least when the blade lets loose, the gyroscopic forces of a blade being spit off will be less. :eek: However I personally know of a Thorp T18 that was lost after the wood prop came undone. It happens. I don't think it was fatigue however, it was just a failure. When you modify ANY engine with a metal prop all bets are off. Hartzell has done the most of any prop manufacture with their (EI) electronic ignition test. However Hartzell has not done any high compression test either. Reading all the info from Hartzell, they seem to have indicated HC pistons alone has the same or similar effect as EI, may be a little less, in their theoretical opinion, since they have not tested it. Combined HC pistons with EI is going it could be worse than just one or the other logically. However vibration does not follow logic, it follows absolute rules of physics. Hartzell found the old standard HC-C2YK/F7666 prop (not the BA prop) went from no life limit to about 8,000 hours with EI or high compression pistons. It's totally unscientific to make correlations to Sensenich, but for grins and giggles. You can assume you have less prop fatigue life than you would with a stock engine. Helicopters are full of life limited parts. Again like a broken record, who knows if it's not tested. I think Sensenich should do an EI test for their reputation. As an individual you can have a prop vibration survey done by Hartzell for about $10,000 to $25,000, rough numbers. The Prop company may be willing to do it free or discounted if there is some interest in it for them, like a new engine, e.g., IO340 or IO390. If its a new new market or product for them than they will want to do it. As a group of Sensenich's customers, Vansairforce, we should ASK them to do it, free. Some one can volunteer the use of their plane, time and gas to do the test and they would do the technical testing and data collection. I think it takes three days or a full weekend if the weather is good. It would be great if Sensenich did this EI test, since this is what their customers are doing with their prop. A Sensenich prop failure and lawsuit would cost more than doing a free vibration test. |
Gasman,
Sorry for the late post. I've been traveling. The Sensenich choice is a long story . . . ;) At the time I was having the engine built up, I was running a beautiful Warnke cruise prop on a 168 hp setup. I anticipated that with the engine "improvements" that same prop would become a climb prop. I was wrong. The aircraft was severely underpropped (a contemporaneous aero cleanup contributed this "problem"). Having just dropped the money for the engine overhaul and wanting badly to fly soon, without the costs and downtime associated with the conversion to constant speed, I opted for a Sensenich 72FM85. Why Sensenich? Quick turn around. Easy installation. No periodic prop re-torque. Good performance. Reasonable cost. Engineers willing to answer my questions about vibration and otherwise. I.e., why is the 72FM only 71" long? And, why is the 72FM so darned heavy? Now, I agree with George's post. My experience is just one data point--nothing more. And, I apologize for my comment about "still being alive". It was a poor attempt at humor. But, these are experimentals. I recognize my engine/prop combo is an unquantified risk. And, in fairness to others who may be tempted to follow me: 1) I don't know very much; 2) I do some things that might tend to mitigate the risk such as: a) retarding the EI timing 5 degrees; b) no sustained operations between 2000 RPM and 2350 RPM; c) operating almost exclusively at lower than average ICP (<21" MAP, 20 deg LOP yielding CHTs <325 deg); d) GAMIs; e) dynamic prop balance, etc. Those are listed in descending order from what I perceive to be most significant down to, perhaps, insignificant. :p Conversely, I typically run the engine at about 2650 RPM on the new digital tach. I used to think it was 2700. :rolleyes: That speed is probably more stressful than the 2400 RPM where we might expect a CS prop to be operated. My normal operating parameters may not be acceptable to others. But, I regularly cross the Rockies. I regularly fly 4&5 hrs non-stop (HW ER tanks--great product, great guys). And, I rarely go "lookin' down chimneys". In fact, I'm rarely below 11,500. I use this aircraft as a "high" altitude cruiser. So, these parameters are no bother for me. Finally, I'll be satisfied with 1000 hours of useful engine and prop life with a prop overhaul at 500 hours (I do get some conflicting views on the effectiveness of this from the Sensenich guys). Again, I'm not advocating this setup. It's just what I'm doing for now. And, I welcome criticism. I hang out here because I enjoy learning from you folks. :D |
| All times are GMT -6. The time now is 06:43 PM. |
