VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   lycoming 0-320 D1A prop governor (https://vansairforce.net/community/showthread.php?t=174)
Build9A 01-07-2005 11:36 AM
When converting from constant speed to fixed pitch set up I removed the oil line that goes from the prop gov. to the front of the engine. I also removed the prop gov. drive and replaced with a cover plate? I am having a tech person look at it tomorrow but wanted to make sure I removed the correct part. Is the tapered cylinder thing with the tooth gear on the end the prop gov drive? thanks
Build9A 02-02-2005 07:26 PM
prop governor
Since no one answered my question, I will provide the answer. Yes it is the tapered cylinder thing with the tooth gear on the end. by the way if you need a brand new prop gov drive for a constant speed set-up on an 0-320 let me know. It's for sale.
mahlon_r 02-02-2005 09:12 PM
Make sure you also remove or puncture the rear plug in the nose crankshaft nose bore area, before installing the front plug!
Good Luck,
Mahlon
Build9A 02-03-2005 08:50 AM
Thanks Mahlon
Good Luck,
Mahlon
Thanks for the reminder. The puncture had been accomplished at the time of the removal/conversion. you are always very thorough and a real asset to the various groups that you participate in. Great to know that you are monitoring this forum. Jack RV9A
