Bravo!!! I didn't want to say it and start an argument, but you are absolutely correct. |
Mooney Nose Gear
The redesigned nose gear has some similarities with the Mooney gear and I wonder if bad piloting technique in an RV-7A with the new gear will produce the prop strike issues that happen with the Mooney 201 series. Getting into ground effect going too fast is always bad news in a low wing, especially for those determined to ?wheelbarrow? it onto the ground. Having been in an RV-6A that had the original (first generation) nose gear collapse due to metal fatigue I do take the issue of a roll over very seriously. Fortunately we were going very slowly when the failure occurred and we didn't roll over but I suspect you wouldn't have to be going very fast to end upside down. Using taildragger three point landing technique in the 7A and staying off the brakes ( planning all landing distances with no braking), paying attention to nose wheel loading to stay under the maximum values in the Vans bulletin and regular checks of the breakout friction loads on the nose gear and my feeling is that the existing gear is adequate and safe if generally operating from paved or good quality unpaved runways. If you want to operate from unimproved strips then the RV?s are not a good choice and the new nose gear, in my opinion will do nothing to improve that. My guess is that landing accidents with the new nose gear will result in more prop strikes and bent firewalls and other forward fuselage damage. Putting $4K into flight training to develop a proper landing technique is more likely to produce a better return on investment.
KT |
Huh, sure seems like something they've "fixed" with this new design. Though the "just land correctly every single time 100% of the time" crowd will never admit it...
You must be really careful landing a Mooney. #1..The Mooney has very little prop clearance, and #2..The main gear is so far back that it is difficult to hold the nose wheel off the ground. Having said that, the Mooney practically lands itself IF your speed is correct. If you speed is not correct, it's almost impossible to make a decent landing. |
Some good advise being given out here. I have watched so many poor pilot techniques landing RV?s it?s crazy..especially the tricycle gear crowd. It?s just not a hard thing to keep the nose wheel off as long as possible. If you get rid of flaps after landing you can hold it off longer by a fair margin. These are really easy aircraft to fly if you give them just a little respect. I too looked at the newer designed nose gear at Oshkosh and it certainly looks like a decent design and when your flying something the size of the 10 I can understand why they chose to beef it up a bit as it?s a much larger and heavier aircraft. If I had a 7 I?d leave it as is as in my mind it?s adequate for the job.
I have owned 5 Mooney?s over the years and you do have to be careful with the nose gear in rougher fields although I never had an issue. There have been lots of Mooney?s that had prop strikes but again if they are handled properly like the RVA?s you shouldn?t have an issue. Handling any aircraft properly begins with where you decide to land and takeoff and taxi so like the Mooney if you chose an overly rough field then it?s poor pilot technique.. |
Endless looping subjective arguments over pilot technique and cost aside, my understanding of the new nose gear issue is as follows:
1. The new gear is now the defacto standard in all new Vans firewall forward kits (but the old gear and old engine mount will remain an option for some period of time). However I can’t imagine that many, if any, purchasers of new FWF kits will want to exercise the option of the old style gear to save a small amount of money. 2. Not many builders who are flying will do a retrofit of the new gear because, cost aside, it will in most cases prove to be a really major project. The extent of the actual task will vary from RV to RV because every firewall set-up is essentially different. Possible conflict problems with baffles, control cables, oil hoses, fuel lines, electrical looms, engine-cowl clearance, cowl-spinner clearance, likely cowl mods, and cowl repainting, to name just a few problematic areas, will deter all but the very few. 3. It is only current builders who have already purchased a FWF kit who have a difficult decision to make, and the further they are into their actual FWF installation, the more difficult the decision becomes. |
There were a mutatude of issues not just one.
Correct form landing,is a must in these light,high performance planes.I wish conditions were always ideal but they are not. There are real problems with the classic gear. The bound up wheel bearings to start,out of round & balance wheels. Then the solid tempered ground steel gear leg that would fold up like limp spaghetti with the slightest provocation,trapping the pilot upside down.Until Alan came up with the anti splat brace(a stroke of out of the box genus). Flying an a without the brace is akin to ridding with out a helmet. Only time will settle the debate. The redesign is a welcome option. The cost and the cost structure is what I'm having a problem with. $3K for me to upgrade,Vans has set the price at $700 for the old gear&mount.Go to buy the old mount new $1200 + the leg $267.50 = $1467.Please don't forget the cost of shipping these parts back or the cost to get the new gear home. Being able to land upright is just as important as pulling out of a spin.A little more help from the Vans to replace the old gear would be appropriate IMHO.
RHill |
Upgrade thoughts
:o
1. Upgrade the original nose gear per MANDATORY service bulletin SB-07-11-09. 2. Update to the new 2019 nose gear. 3. Convert to RV6 tail wheel. I plan to base the plane at my farm strip which is 650m/2000' grass, it is not overly rough but it is not smooth either. A couple of RV6's have used the strip without any trouble other than some vibration from the Kikuyu grass being uneven up and down about 1 inch. Implications for the above options are: 1. Purchase new nose wheel fork, $205 + shipping. Rethread and shorten the gear leg, $500 return shipping + $70 to Langair, or do it myself using a die. Or purchase shortened gear leg $267 + shipping and get machine shop to match drill to engine mount. 2. Purchase retrofit kit $3225 + carb kit $115 + shipping. 3. Purchase TD configuration engine mount, gear legs, tail wheel. Cost guesstimate $2000 + shipping. If going for option 1 then will also need to consider fitting an "anti-splat" reinforcement and improving the nose wheel axle/bearing setup. I've seen too many pictures of inverted -A models and really don't want to end up that way, so that's the main motivation. I'd also like to keep costs down, within reason, but building a 'plane is not really about saving money... These are my thoughts so far. It's a bit of a conundrum but great to have choices. |
Camp 3
I am in camp 3. But to me the change is a no brainer. When the plane is done, the difference in cost will not be significant. I know I can fly the plane and keep my nose clean ( pun intended) but I dont know if others who might happen to fly my plane can land properly. The worst scenario is someone has to fly my plane home and they ding it. I sense the original builder, who put their soul into the plane, is not the concern.
tapered pin to replace bolt legacy nose leg to motor mount
Now I fly a Rocket (TD), have hundreds of hours on it, and worry about loss of directional control/groundloop on landing and worry about x-winds more than I did with the -7a. It's a blast to fly, but I am not less anxious about landings than I was with the -7a. To be honest I miss the nosewheel. Put a tailwheel on your RV because you would like the experience of having and flying a plane that's a TD. Nothing wrong with that. But don't kid yourself - if you screw up you can become upside down just as fast as in a -A. As the saying goes: you pays your dollar, you takes your chances. |
Thanks for the reply Mark! good to hear perspective from someone who has flown a lot of hours in both. I learned to fly in TD's and love them, but chose to build a 7A. I still thinking babying the nose wheel is the way to go (in any aircraft) but I opted to update for the extra margin of safety if I should even need it.
New nose gear.
I think there is a misunderstanding concerning the new nose gear. One must understand that the RV ?A? models are like the Cessna 150/152, that is a very short wheelbase nose gear airplane that also happens to have fairly high touchdown speed. The new gear is designed simply for a smoother ride on the ground. If one has ever been in a -10 (or -14), he or she would be impressed with how smoothly it rides on the ground. It has nothing to do with a possible flip over. The new gear works on compression not extension. And the fact that people are building ever heavier RV?s. It is under the category of product improvement. You have to that know Van thoroughly examined the whole issue of nose overs. Just land it correctly. I have personally seen two RV-8 tail draggers end up nose down and tail up.
| All times are GMT -6. The time now is 03:19 AM. |
