VAF Forums
-   -   A left wing heavy RV-6A (https://vansairforce.net/community/showthread.php?t=173804)
Earl Findlay 07-29-2019 11:31 PM
I was able to fly in an RV-6A this morning. What a ride!
One thing that I noticed is that the airplane was very left wing heavy. In other words, it would not fly straight and level hands off. I noticed that the left aileron on this airplane was slightly higher than the right, which would seem to be the cause of the left wing heavy appearance, but I am not certain.
My question, as a soon to be builder .. if this happens on my build, is it something that can be fixed without huge amounts of trouble? Or, is it an "oh $@*@ moment, and you're forever stuck with an airplane that does not fly straight, or face the prospect of rebuilding a portion of the airplane? I suppose that this means at some point, the builder neglected to check something??
arffguy 07-29-2019 11:59 PM
Here you go:
https://www.vansaircraft.com/faq-tec...-a-heavy-wing/
There's plenty of discussion here on the forums too.
BobTurner 07-30-2019 12:13 AM
This exact thing happened to me - left wing heavy on my -10. Sighting down the top of the wing I could see the left aileron was slightly higher than the right one, on the outboard end. Maybe 1/32 - 1/16?. Removed the aileron, removed the mounting bracket. Used a file to elongate the hole about 1/32? vertically. Partially filled the hole with JB Weld, re-drilled, filed sides flat. Remounted everything, heavy left wing is now gone. If you need more than a bit of elongation, Vans sells undrilled brackets for just this purpose.
scsmith 07-30-2019 12:30 AM
What Bob Turner is describing is balancing the height of the aileron skin at the hingeline gap with the wing skin. If you lay a straight edge on the wing skin, overhanging enough to go back over the aileron, with the aileron fixed in the true neutral position (lined up tooling holes in tip rib as per the instruction manual), then look at the gap or contact between the straight edge and the aileron skin.
You would like them to touch, or for the aileron to be slightly high, so that the straight edge is lifted up off the wing skin slightly. Something less than a 1/32" or so. You would prefer not to have the aileron skin low. BUT the key is that this arrangement should be the same left and right, and the same at the inboard and outboard ends of the aileron.
It is a safe bet that the aileron on the side that is "light" (meaning it rises if hands off) is set below the wing skin by more than the other side.
The aerodynamic mechanism at work here is something I have explained in other threads. But all you need to do to fix it is as Bob Turner suggests, adjust the hinge bracket up or down as needed, most desirably by making new brackets.
BillL 07-30-2019 05:35 AM
Yes, a heavy wing can be corrected.
Apparently, it is not hard to build a heavy wing. I had one, my 10 friend had one. Yes, a heavy wing is fixable. Undrilled hinges are available for the 7, not sure if the 6 is the same, and none are available for the 10. They can be welded and holes moved.
SCSMITH is the man!
WingsOnWheels 07-30-2019 06:14 AM
I have a heavy right wing at the moment. I am about 12hrs into my phase 1. For now I added a trim tab to the bottom of the light aileron, once I install the wheel pants and gear leg fairings, I am going to adjust the hinge brackets. I will slot them for testing and then replace once I have determined the correct position. The ailerons are in trail when I hold the wings level, so I am confident the vertical adjustment will solve the problem.
WingsOnWheels 08-11-2019 08:14 PM
I wanted to follow up on this thread. I had a heavy right wing. After careful measurement, I decided to shift the right (heavy) aileron down 1/8". I test flew it today and my heavy wing is 90% gone. I need to make a few other minor tweaks, but it looks like this was the right way to go!
jpowell13 11-06-2019 08:34 PM
Wing heavy 6A
I've lived with a left wing heavy 6A for too long. Finally tried rotating the nose gear leg fairing trailing edge a few degrees away from the heavy wing and flew today. Problem solved. John
jdmrv7a 11-07-2019 09:20 AM
Heavy wing- RV14-A
John,
How far out (left or right) was the ball? Did you add a trim tab or adjustment to the flaps or aileron? Was it just a simple rotation of the nose gear leg fairing?
I am in the process of making some adjustment on my RV 14-A so I can remove the taped-on trim-tab under my left aileron and right side of my rudder.
The Van's "Heavy Wing fix" memo was not written for the RV14-A. Any expert recommendations would be appreciated.
AAflyer 11-07-2019 04:55 PM
Trailing edge radius
Why is noone talking about squeezing the trailing edge of the aileron, per Vans plans, to alleviate this condition?
