In this context, lower MP/ higher altitude advances the timing compared to a fixed magneto. So yes, "advanced timing" means exactly that - the plug is firing earlier in the piston stroke/crank rotation. |
Confusing throttle with MP
I think you?re confusing throttle and MP. During cruise at 10,000? with wide open throttle and leaned out, my manifold pressure is low and even with high rpms my power output is below 60%. This is an example of where the ignition advance lives. Ignition is not retarded, it is advanced. At altitude, in cruise, leaned out is where you get the advantage of the ignition advance. As others have stated, other benefits of EI include easier starting and smoother idling. |
Finished installing my Surefly today. Longest part of the install was getting a cotter key on the mag gear to my satisfaction. It comes with one - I was lucky to have a bag of 25 of them. Funny how the shortest items in the instruction manual usually take the longest.
Anyways, I was immediately impressed at how quickly it started, both cold and hot. It really is like starting a car. Idles smoothly much lower and I can lean it much farther on the ground. I am in fixed timing mode for now, so not sure how much the efficiency will change, but I will probably experiment with the variable timing mode eventually. I also had to move my one EIS tach input to the right magneto, but that was an easy fix. Chris |
| All times are GMT -6. The time now is 04:55 AM. |
