VAF Forums
-   -   Vans RV Fuel Fittings (https://vansairforce.net/community/showthread.php?t=173568)
dshevick 07-21-2019 10:07 AM
I have a very small seepage leak in my fuel system (fuel selector/boast pump) and I'd like to pressure test it to find it. I know not to pressurize the tank, but I was looking for some flare fittings to replace where the tanks are. The fittings are not standard 5/16 or 3/8" flare. where do i get this type of fitting? thank you david
Ted RV8 07-21-2019 10:10 AM
Aircraft Spruce
TS Flightlines 07-21-2019 04:19 PM
David what selector valve do you have? The Vans Imperial valve has 1/4 NPT threads, The Andair 'could be ' 1/4 NPT or -6 An depenting on what model valve it is.
Tom
gasman 07-21-2019 10:58 PM
Take a paper towel and cut in one inch strips. Wrap each connection and tape in place. You will find it soon enough.
