UHMW Anti Friction Tape
My painter suggested using this UHMW tape on my gear doors, and flaps, to prevent "scuffing" the paint in this area.
Has anyone here used this? Is there a particular brand that is better? Thanks! |
https://shop.vansaircraft.com/cgi-bi...oduct=uhmwtape
Flyboys carried it also but couldn?t find it on their website. |
Thanks! |
Holds up well but will yellow when exposed to the elements.
Been on my plane for 12 years and still functions fine even though it’s yellowed. The flyboys stuff was said to hold up better to the yellowing. |
I see it is available through Aircraft Spruce also. Plus Amazon.
An option, if you have silver or gray wings, is to use a stainless tape that is mentioned in posts elsewhere on this site. Search the Forums for it as people seem pretty happy with that. Chris |
Northwest Regional? Aero Valley? I'm in Denton, KDTO. |
The uhmw tape sucks. It yellows and gets brittle over time. The good stuff is available from Flyboys or from PM Research. More expensive for a reason.
It should be applied to whatever surface you are trying to protect. Erich |
| All times are GMT -6. The time now is 01:04 PM. |
