VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   How to remove baked on intake gaskets? (https://vansairforce.net/community/showthread.php?t=173365)
digidocs 07-15-2019 09:59 AM
What are your favorite methods and tools for removing baked on cylinder intake gaskets?
Those little buggers are hard as a rock and the access is somewhat limited!
Thanks for the help.
lr172 07-15-2019 10:27 AM
I tend to use a razor blade. a sharp putty knife will also work. If not comfortable with that, agressive solvents will soften it up a bit, but still need something to scrape it off with.
Larry
scard 07-15-2019 10:43 AM
phenolic scraper
