Originally Posted by dreed
(Post 1359275)
Looks Great! How do you like the full size Ipad? I am on the fence as to what size to get.
Yes 10" pro, love it! Shows a map in this shot but mainly used for IFR plates.
Originally Posted by Ferdara
(Post 1359305)
Where is your fresh air vent?
Can't really see them but they are in the lower left & right corners of the panel along with the phone plugs.
Originally Posted by Draker
(Post 1359315)
Wooooooow! Here I thought dual 10" displays side by side was the only way to go with G3X. Have to re-think my whole world now! Correct me if I'm wrong but this layout looks like it has the advantage of not having to re-locate those ribs between the sub-panel and panel. Looks like you're using Van's stock location for the screws.
I relocated the LH rib OB about 2 inches, the RH was removed all together, the radio stack and control cables are anchored to the sub panel so the panel is quite rigid.
As a side note both ADAHRS are attached to the subpanel to avoid any vibration issues.
