VAF Forums
-   -   Best way to drill .505" hole for antenna? (https://vansairforce.net/community/showthread.php?t=173159)
hevansrv7a 07-09-2019 08:56 AM
My plan right now is to use a step drill that goes up to 1/2" and just over-do it a bit, by hand.
Is there a better way?
13mm drill bit? (.512")
I have done this once before but I've forgotten how I did it.
Auburntsts 07-09-2019 09:11 AM
I'd use the step to .5 and then file it to final size because those are the tools I have.
fl-mike 07-09-2019 09:46 AM
drill to 0.5" with step drill and take a couple thou off with the dogleg deburring tool, if you have one. Otherwise some abrasive cloth or file.
David Paule 07-09-2019 10:05 AM
What Mike said.
Dave
WingsOnWheels 07-09-2019 11:50 AM
Same here!
Perreaum 07-09-2019 12:11 PM
Maybe I'm just sloppy with the stepdrill, but I usually get some slight deformation when I use it.
I found the rotacut tool did a cleaner job because it has a center guide and little pressure is required. Then I use a deburr tool to go up slightly if needed.
hevansrv7a 07-09-2019 02:17 PM
Got it. THANKS.
I think the step drill plus a little finesse with a deburring tool sounds good and I do have one or two!
Thanks to all.
cajunwings 07-10-2019 09:40 AM
Upsizing
I have a tapered hand reamer that I use a lot for tasks like this.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
A&P-IA-ATP
SMRacer 07-10-2019 10:45 AM
Rota cutters
I don't know why these cutters are not a more common tool amongst builders.
They cut a perfect hole in sheet metal. No distortion.
https://www.mrmtool.com/Hougen-11075...Kit_p_755.html
flyinga 07-10-2019 05:12 PM
.5 step drill with #2 wobble
