Vernatherm tech questions
Ive had a sudden increase in oil temps. I want to eliminate the vernatherm from the troubleshooting process, ive checked it and it extends at 185 degree as it should however it only extends 1/8 inch (.125) and everything ive read says it should extend at least .160 inches
Also the part number has a suffix of A and I dont see that anywhere in parts manual. Any info out there? Cm Ps ive searched the forum already |
I was able to speak to an engineer and .160 was the figure he gave. The nut is crimped. Im hoping the difference between .125 and .160 fixes the issue.
I was seeing a 10 to 15 degree increase in oil temp. A new vernatherm is on its way. Thanks for the info Cm |
I have always been curious as to the failure mode of Vernatherm valves. It is just a bimetallic spring, but they fail often enough to be one of the first troubleshooting items. Does the bimetallic junction fail somehow?
Still not sure about the failure mode. |
Failure mode
I had not seen a jump in oil temps until the weather warmed up and after I removed the winter tape covering the oil cooler duct. The vernatherm could have been slowly failing since last fall. To complicate things I broke the oil temp probe in november and the first replacement sent the gage to the highside peg and the second one checked accurate but then I started seeing higher temps so I was skeptical about it too. I hope the new vernatherm puts the temps back to what I consider normal
Cm |
Cooler
I checked the sealing surface on the adapter and it looks ok
The sealing surface of the valve looks like it was making uniform contact If my math is correct valve was leaving a .035 gap Last summer On an 80F day temps 180 90F day temps 190 100F day 200-210 max Recently. 80F. Oil temp 200 90f. 210 90+. 210-215 I know there are variables I guess we will see if that .035 gap equates to about 10 deg difference. If the plunger moves 78% of its travel how would that effect the fliw of oil to the cooler? I would be nteresting to model the flow Cm |
| All times are GMT -6. The time now is 01:05 PM. |
