Partial power-failure, slight vibration and surge. Cleared itself on low power Ideas?
Hi folks.
During a local flight yesterday, after approx 10 mins on stabilized 50*F LOP cruise at 3000', (55%: 21 inch/2350 RPM) I suddenly noticed a slight vibration and felt slight surge in the plane. (like slight power addition, slight power reduction, 1 sec intervals.) No surge indication on MAP and RPM. They where stable at 21/2350 All four EGTs's where indicating increasing LOP: approx 80-120 LOP. CHT's where climbing from the usual 330-350*F to 430-450. I turned towards the homefield (10 mins away), moved the mix towards full rich and started a slight climb. That stopped the LOP to go further towards lean, but the CHT's where still higher than normal. And the slight power-surges and vibration continued. Changing fueltank had no effect. Ignition where in "Both" the hole time. When approaching the field and within gliding distance, I slowly reduced power and passing approx 15 inches, I felt the vibration and surge go away. After landing, I did a runup-check with all normal indications. Tomorrow, I'll pull the cowls and start checking things. Any ideas to where to start looking? Setup is a Lyc IO-360, dual P mags, 220 hrs TT. Thanks. |
| All times are GMT -6. The time now is 11:52 AM. |
