5 pages (so far) discussing how to lift an engine out of a crate with an engine crane,,,,,,I am at a loss for words, yet somehow we can build an airplane.;)
Too funny...and so true. :D:rolleyes::cool:
Hey, we got you. This is what makes the VAF hive mind so valuable :)
https://i.ytimg.com/vi/me5ZuyrU65o/hqdefault.jpg |
Glad I could add some amusement to the forum. I did not realize picking cherries would lead here.
To remove engine, open up, remove / peel away all the foam bags on top and hoist. Pull box off and continue to peel away the packing material putting it all in the box. Inside is the engine manual along with a logbook and papers on how to correctly bring the engine to life. If able, store the box and packing for future use. I store my engine and prop shipping container wrapped in plastic in my hanger, up high, tied to ceiling and wall. I do this to guarantee that the engine and prop will always work perfectly and all my troubles was for nothing. It was Christmas deluxe. R |
weird--my IO390 was not packed that way. No dessicant anywhere in the crate/box. Lycoming asked me if I wanted foam around it for long term storage--just in case factor. I said yes. They put in a large sheet of thick plastic on top of the engine and sprayed in foam around the sides of the top. After taking off the top wood cross supports the foam pulled out with no issues--it was not tight at all. I then cut off the cardboard box. The engine is held down to the bottom with plastic straps and a metal plate that connects the flywheel. It was a 10 minute exercise--but I have not unbolted the flywheel yet.
FWIW, I specifically declined the long-term preservation. It’ll be interesting to see how it’s packed once it finally arrives.
Engines I've received (Aerosport & others) have come on standard pallets with plywood sides & tops, so they were too big to get the engine hoist under if the driver set the pallet directly on the floor. It's easy enough to pry up the corners & build up the height with stacked 2x4s so the hoist legs will roll under. At this point I open the crate (plywood or cardboard, doesn't matter) & lift the engine & pallet with the engine lift ring, place 2x4s sideways accross the hoist legs & lower the pallet so it rests on the hoist legs, store it there & move it around as necessary till I actually mount it on the plane. Easy..
| All times are GMT -6. The time now is 03:47 AM. |
