VAF Forums
-   Glass Cockpit (https://vansairforce.net/community/forumdisplay.php?f=35)
-   -   GTN V6.62 Software Update, May 30, 2019 (https://vansairforce.net/community/showthread.php?t=171970)
g3xpert 05-30-2019 10:12 AM
--- Updated June 10, 2019, Software Available Now --
Hello,
The GTN V6.62 EAB service bulletin and software are available for download in our standard location on the G3X/G3X Touch software download page.
We are very pleased to announce some new GTN integration with G3X Touch including display of the selected altitude intercept arc on the GTN map (like is already shown on the G3X Touch map) and VFR flight plan editing on the G3X Touch displays and automatic transfer to the GTN.
Here is a list of new features and improvements in GTN V6.62:
  • G3X Touch flight plan editing - Pilots who have a GTN 6XX/7XX installed alongside a G3X Touch flight display in an experimental/amateur-built aircraft now have additional flight planning and editing options. VFR flight plans can now be completed on the G3X Touch display, and then automatically synced to the GTN for added convenience when using either the G3X Touch or GTN.
  • The GTN 6XX/7XX now displays a selected altitude intercept arc on the moving map when it?s installed with a Garmin primary flight display (PFD) such as the G500 TXi/G600 TXi, G500/G600 or G3X Touch. When pilots input a preselected altitude on the PFD, the selected altitude arc will populate on the map page to indicate where the aircraft will arrive at that particular altitude.
  • For customers with SiriusXM Aviation Weather, pilots now have the option to alternate between base reflectivity and composite reflectivity NEXRAD weather radar imagery.
  • Improved availability for advisory vertical guidance (LNAV+V) on LNAV approaches in areas around the world without SBAS coverage.
  • When SiriusXM aviation weather or FIS-B weather cannot be displayed on the GTN 6XX/7XX, the ?no coverage? area of weather is transparent so pilots can still view airports, basemap information and more.
  • A VNAV aural alert is now available for Top of Descent (TOD).
  • Traffic and weather from a GNX 375 can now be displayed within the GTN 6XX/7XX.
  • When paired with a compatible ADS-B In product such as the GTX 345 or GDL 88, pilots can now access the latest FIS-B weather products on the moving map alongside flight plan information and dedicated weather pages within GTN 6XX/7XX. These new weather products include lightning, cloud tops, turbulence, icing (current and forecasted), graphical AIRMETs and center weather advisories (CWA).
Note: To utilize flight plan syncing between G3X Touch and GTN 6XX/7XX, GPS 175, and GNX 375, "External FPL Crossfill" must be enabled in normal mode on the System Setup page, and "External FPL" must be enabled on the Main System configuration page in configuration mode.
Steve
Jasonm 05-31-2019 06:00 AM
Thanks for the update Steve. What about the 625 units? Do any of these features apply?
olyolson 05-31-2019 06:39 AM
GTN 650 software update
Steve,
Although your post doesn?t specifically mention the GDL-39 3D, this device has two data in/out connections. Would one of these data in/out connections be able to display ADSB in on the GTN 650.
g3xpert 05-31-2019 06:41 AM
Hello Jason,
Yes, these features apply to the GTN 625. I edited my posting to reflect this.
Steve
g3xpert 05-31-2019 06:43 AM
Originally Posted by olyolson (Post 1349922)
Steve,
Hello Oly,
The GTN does not interface to the GDL 39.
Steve
KatanaPilot 05-31-2019 07:30 AM
Kudos to Garmin
The ability to push flight plans from the G3X to the GTN has been the one thing I most wanted to see as an added feature.
Thanks so much for the continual improvements to an already superb series of products.
g3xpert 05-31-2019 07:41 AM
Hello Krea,
Your are very welcome, and thanks for your kind words.
Steve
Cannon 05-31-2019 05:06 PM
How is VFR flight planning different from IFR flight planning? Is it just the ability to load approaches?
g3xpert 05-31-2019 09:52 PM
Hello Cannon,
That is close.
VFR flight planning is the flight planning you can currently do with a G3X Touch system. You can create a flight plan with airports, VORs, NDBs, intersections, user waypoints, and even cities, and each time you edit the flight plan, it is automatically sent to the GTN.
Should you need to load a published departure, arrival, or approach, you would need to switch to the GTN to perform that function.
Steve
Finley Atherton 06-01-2019 12:42 AM
Steve,
No SBAS in Australia but I already get LNAV+V on my GTN650 so what extra does this new update (point 4) give?
Fin 9A
Australia
