VAF Forums
-   Safety (https://vansairforce.net/community/forumdisplay.php?f=100)
-   -   Carbon Monoxide Detection (https://vansairforce.net/community/showthread.php?t=171672)
AirHound 05-20-2019 05:35 AM
Anyone using a sensitive electronic monitoring device have any suggestions on a best one? Thank You!
catmandu 05-20-2019 06:44 AM
I did some reasearch and best bang for the buck I could find was a Sensorcon. ?Aircraft2017? 20% discount code seems to be still active.
TShort 05-20-2019 07:28 AM
I put one of these in the -10:
http://www.fdatasystems.com/gd-40-co-detector/
I get alerts, and a readout in ppm (pretty sure those are the units) on the display of the G3X. Very happy with it.
The business owner is on the forums and is an RV guy.
bkervaski 05-20-2019 07:31 AM
Just about everyone at our field uses this one ...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Mike S 05-20-2019 08:07 AM
Another vote for the Flight Data System unit--------when I was looking for a detector for the RV10, I found out that these units need a replacement sensor periodically------the FDS was the longest lasting and the cheapest to replace.
rongawer 05-20-2019 10:19 AM
That's the one I have. Works great. I have found it lasts about 6 months on a battery if I leave it on continuously.
AirHound 05-20-2019 11:27 AM
CO Detection
Thank you for the choices, I?d rather pick one of them than rely on the stick-on, color changing type.
Will any of them show trends? For example ppm changes which can be used to analyze cabin leakage during different phases of flight. Or, are they basically just real-time readouts and peak numbers-which work too?
Any common/unique CO activity associated with ELSA RV12?s in general? Or, expect 0 ppm if built to (ELSA) KAI specs?
Thank You
Doug in IL
TShort 05-20-2019 11:46 AM
Mine is connected to the G3X, I have an ongoing display of CO levels, and alerts above a certain level. I also installed the LED next to the test button on the panel.
The data stream is recorded in the G3X logs, and available for review in the data set (i.e. on download to savvyanalysis.com etc)
I really like the unit, have been very happy with it.
cdeerinck 05-20-2019 03:58 PM
This is the bomb
https://aithreaviation.com/products/aithre-shield-ex
Connects to Dynon SkyView, Garmin G3X and Advanced Flight Avionics. They can log the data.
drtgraves 05-20-2019 07:52 PM
No one mentioned guardian avionics. I bought one at sun n fun but haven?t installed yet. Feedback?
