VAF Forums
-   Canada (https://vansairforce.net/community/forumdisplay.php?f=67)
-   -   Temporary Vinyl N-Numbers (https://vansairforce.net/community/showthread.php?t=171403)
The Wizzard 05-10-2019 09:44 AM
Has anybody had any experience with temporary N-numbers for flying in and out of Canada? My concern is the ability of the n numbers to stay on the side of the airplane as well as the ease of moving them without damaging the paint on the plane.
I want to make a trip up to alaska and only have 3 inch letters on my plane. I found a website called numbers.com that sells them for $60.00. Any suggestions?
RV10Pilot 05-10-2019 10:19 AM
Shoe polish. Not pretty but cheap and temporary.
az_gila 05-10-2019 10:29 AM
Not Needed for Canada
Unless you are crossing an ADIZ you don't need them...:)
DanH 05-10-2019 10:43 AM
Peel trucks at work all the time. Fresh vinyl is easy to remove.
The Wizzard 05-10-2019 11:27 AM
Peel Trucks
Dan what do you mean by Peel Trucks? So If I fly up the AL-Can Highway I don't need them?
lr172 05-10-2019 11:57 AM
I have permanent vinyl N numbers and still there after 600 hours.
Larry
RV6_flyer 05-10-2019 12:19 PM
Larry
My 3" N numbers are also vinyl and they are over 20-years old and 3,000+ flying hours.
IF you want 12" Vinyl registration marks for ADIZ flight then remove them, the permanent ones Sporty's sells are / were $35 a set. They come off without a lot of work using a hair dryer.
N15JB 05-10-2019 12:44 PM
I have used blue painters tape several times. Surprisingly it doesn't blow off.
texdog 05-10-2019 12:55 PM
Alcan
If you don?t cross an ADIZ, which you won?t on the Alcan, 3 inch numbers are fine. I?m planning on crossing from Cut Bank to Lethbridge next Friday. Three inch numbers.
DanH 05-10-2019 01:29 PM
I mean I'm a truck dealer, and we remove vinyl letters and wrap from used trucks all the time. I would not be concerned about removing vinyl N-numbers less than a year old, more if the aircraft is hangared.
