Fitting that snaps on/clamps on brake bleeder nipple?
Hi VAF,
Does anyone know of a fitting that will snap on/clamp on to the brake bleeder nipple fitting? I've been using a length of hose but it pops off all the time and makes a mess. Brakes are Matco. Thanks! |
My old ATS bleeder came with such an animal.
I secured mine with safety wire.
Check Aircraft Spruce for this:
https://www.aircraftspruce.com/catal...lickkey=980347 I think that’s what you’re looking for. Cleveland Brake Bleeder Adapter. |
That looks great! Thanks for all the quick replies.
Try a smaller hose. I just pressure bled mine last night with regular 1/8 clear hose. Didn't have any issues.
Any grease gun will have that fitting. I simply unscrewed it from one of my older grease guns, took it apart and cleaned out the grease.
Just looked online. Grainger has the fitting for $2. Many others between that and $5. |
1/4" nylon
I used a piece of quarter-inch OD static/pitot tubing. It slipped inside the tubing called out in the DIY garden sprayer bleeder plans (safety wire to secure), and the ID was perfect for a slip fit over the bleeder zerk.
I'll grab some photos this evening if I remember. |
The advantage of the grease gun fitting is it is a check valve so you won?t spill any fluids.
However, as little as you need it, cleaning up a few drips of fluid now and again isn?t that big of a deal. Use whatever works. |
| All times are GMT -6. The time now is 04:55 PM. |
