Bearing hole to case alignment ?
Folks,
Any engine builder here ? I have started the building of my 360 and first I do a test assembly. I discovered the holes in the bearing aligns very badly with the holes in the crankcase. Anyone who knows about this is normal ? https://lancairtalk.net/download/file.php?id=12721&t=1 |
Well
When I rebuilt my continental o300 I ran into this. After several calls to continental, I was told this was pretty much normal(!?!). They did say that if the case was still disassembled, it is possible to “use a countersink to create a larger diameter hole” in the case journal. They also said that if you could see 30% of the case journal hole through the bearing hole, it was ok.
Take it for what it’s worth. I opted to slightly enlarge the holes with a countersink. Engine ran fine and had north of 1000hrs on it when I sold the airplane... |
It's normal for them to not be perfectly aligned.
Good Luck, Mahlon |
| All times are GMT -6. The time now is 05:33 PM. |
