VAF Forums
-   RV-4 (https://vansairforce.net/community/forumdisplay.php?f=9)
-   -   Vibration after new mounts installed...looking for advice (https://vansairforce.net/community/showthread.php?t=169795)
Taildragger19 03-19-2019 03:22 PM
I just installed new Barry engine mounts 94011-20
Has gel inserts. I was hoping to get a bit of sag out from the old mounts that have been in for years. Got a bit of a lift, not as much as I wanted. Now I Have an overall increase of frame vibration. I?m going to go with 15-20% more. Is this just due to stiffer mounts? Am I going to see damage to other areas because of raised vibration? Will it subside a bit after mounts get worked in a few more hours?
I did not build my Rv4. I have done extensive work to it. I0360 power, constant speed prop. I do lots of formation routines and light acro with it. Any advice or input would be really appreciated.
dlloyd3 03-19-2019 03:35 PM
Did getting rid of some of the sag bring the engine, baffles or exhaust into contact with any part of the airframe?
Taildragger19 03-19-2019 04:50 PM
Hi,
There was very little sag correction. Half of what I was hoping for . Nothing in contact. Thanks for response.
