New Eggenfellner redrive pics
These pictures are rather large from the Eggenfellner website, but they show some nice detail of the Gen 3 drive.
![]() ![]() Here are the three generations of reduction drives that the factory has produced. ![]() The Gen 3 is 2.02:1. To see the pics in smaller format, check out the Eggenfellner news page here :cool: :cool: :cool: |
Who will do the testing
Are they going to test it before release and the data from the testing? Or will the customers be the test pilots? I think 500 hours of testing is reasonable.
It's been in testing for quite some time now. I don't know the hours they've put on it, but it is being tested.
Glenn, you know as well as I do that the customer/builder/pilot of any amature built airplane is every bit of a test pilot as the next... :) Here's the link to the performance page on Eggenfellner's website with info on the numbers with the 2.02 redrive. |
Aerobatic?
CJensen, can a -7 do aerobatics with this combo? Same restrictions as the Lyco with +G maneuvers?
Thanks Shawn |
Yep, positive only. There are some other things to consider if doing aerobatics with this combo, but it can be done safely.
:D :D :D |
AH! I knew there had to be someone behind that! DARWIN!! :D
The flange appears to be an investment-casting. I think I would want a one-piece steel forging of the flange and final drive shaft if I were using a re-drive.
| All times are GMT -6. The time now is 08:55 PM. |
