VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Sad Concord battery (https://vansairforce.net/community/showthread.php?t=169509)
Capt 03-09-2019 09:56 PM
Sad Concord battery
Hi Guys.
I have a failing Concord RG25XC battery in my RV8 (conventional U/C) and was wondering what alternatives (Odyssey perhaps? Earthx 900?)I have for a lighter battery & the obvious modifications I need to do to fit said battery to the Std Vans battery holder?
Cheers
rv7charlie 03-09-2019 10:29 PM
Should be simple with a pc680 style agm battery. Just make a couple of wood or foam spacer blocks to keep it located where the tie down strap misses the terminals. Worked fine in my 1st -4.
Capt 03-10-2019 01:27 AM
I notice the smaller Odyssey batteries have a low CCA ability compared to the Concord range?
goatflieg 03-10-2019 03:39 AM
Is your battery tray forward or aft? I had a friend make up a tray adapter for my PC-680 on a 3-D printer. Also had to make a thick shim plate for the top of the battery in order to be able to use the stock Van's tie-down bar and long bolts. I used an old PVC cutting board, cut to shape.
paul330 03-10-2019 03:42 AM
I changed the Concorde for an EarthX 1200 on my RV-10. Just had to add a piece of angle to shorten the battery box. Also, you need to run a cable for a warning light or to your EFIS. The -900, of course, will be smaller.
I saved 15lb weight so it may adversely affect your W & B.
RV6_flyer 03-10-2019 07:27 AM
I needed the weight of the battery in my RV-6 to keep CG where I wanted it.
Concord makes the AGM-1234T Chairman battery and it is the same size, weight, and spec as the RG25XC. The terminals are reversed and the battery terminal screws are a different size. The Positive and Negative terminals are reversed on the Chairman battery. The Chairman battery is 1/3 the price of the RG25XC.
IF you have enough battery cable that you can cross the terminals, the AGM-1234T can be used to replace the RG25XC. This is the outfit that had the best price / deliver schedule when I needed my battery replaced earlier this year.
Spacers work on the PC-680 battery in the battery box like others have said. The PC-680 will also save you some weight and you will only give up a little (~7) Amp-Hour capacity.
Capt 03-10-2019 03:41 PM
Thanks guys for the advice/options.
Shall go see my maint organisation who look after my 8 armed with options:)
My current batt is located on the firewall, IO360 CS prop, it's always slightly nose heavy so a lighter batt might just be the go:)
Mconner7 03-11-2019 07:28 PM
Less expensive option
I bought this one for my RV-10. It was slightly shorter than the Concord 25XL and spins my O-540 just fine.
https://www.apexbattery.com/intersta...l-battery.html
Capt 03-12-2019 01:49 AM
Thanks for the info, I'm down under so we don't have the battery choices you guys do -:(
