VAF Forums
-   RV-4 (https://vansairforce.net/community/forumdisplay.php?f=9)
-   -   Electric Pitch Trim (https://vansairforce.net/community/showthread.php?t=169286)
MS1095 03-02-2019 02:50 PM
Electric Pitch Trim
Does anyone have a copy of the electric pitch trim installation instructions from vans that they could post or send me? Also, what is included in the kit? It costs $325 from Vans and the servo, push rod and clevis are less than $200 from Ray Allen.
JonJay 03-02-2019 03:00 PM
Here is an idea from Randy Lervold. I would consider this on the 4 vs the servo mounted in the elevator. Some research and noodling required.
http://www.romeolima.com/rv3/rv3work...#ElectricFlaps
dlomheim 03-03-2019 08:45 AM
RV-3/4 electric pitch trim
I replaced the wire push-pull on the RV-3 I renovated with an electric trim motor as Randy came up with. Worked great and was pretty simple to do.
Doug
RV-3A sold
RV-9A w/Mazda 13B FWF
FinnFlyer 03-03-2019 11:00 AM
EET-1
Here you go:
https://drive.google.com/open?id=1l6...T_Rm8qzVI9W2ac
It's on the RV-4 USB stick from Van's. Second to last page I think.
https://drive.google.com/open?id=1H3...NWTYo55tR7hRkr
I used a T2-10A and a bent (heated with welding torch) 1/8" steel rod to keep it light, simple and low drag. I drilled out lower skin rivets and took out the existing stiffener and made my own 0.032 angle/stiffeners. The servo is sandwiched between the cover and rivnuts in angles running from front spar to rear spar/rib. Doing it with without turnbuckles (fixed length rod) makes for extra work and/or making the horn after making the rod. I have a about 1.25" between piano hinge point to rod hold in the horn and get about 20/30 up/down movement; less than the specified max 25/35.
Finn
