VAF Forums
-   -   VANS IE411 Fuel Pressure Sender (https://vansairforce.net/community/showthread.php?t=169129)
mullokintyre 02-25-2019 02:13 AM
I have installed the IE411 15 PSI fuel pressure sender supplied by Vans. Does anyone know what type of sender this is? Is it variable resistance where pressure decreases/increases with resistance, or a linear voltage type?
Thanks Mick
N520TX 02-25-2019 07:31 AM
As pressure increases,
resistance decreases.
I did a short video for the oil temp sender to find out the right values I needed to program my MGL oil pressure sensor. The fuel pressure sender will be similar in operation.
https://www.youtube.com/watch?v=IrlXqanE6Jo
--Ron
mullokintyre 02-25-2019 02:46 PM
Thanks Ron, I also have an MGL equipped aircraft.
Mick
