CS prop use with high compression pistons?
Can anyone shed some light on this? I've seen several threads talk about various engine types and CS prop combinations that shouldn?t be matched.
Can you mate a Hartzell CS to a 0-320 with high compression pistons? And do all 0-320?s advertised as 160hp have them? What about electronic ignitions and Hartzell CS props? Thanks for any info! |
Not tested. Thats the catch, there may or may not be a problem. PLENTY of people run Harzell CS props with high comp AND EI with no problems, but it hasn't been tested on that combo.
160HP O-320's are standard, not considered high compression. High Compression would be closer to 170-180HP. |
Look at the Twin Comanche. It tuns a type-certified IO-320, 160-hp, Hartzel CS prop arrgt. Check the Lycoming TCDS for the "approved" combinations.
If it concerns you so much, then ditch the -320 with the EI, etc. and go with a bigger engine. A 160-hp with a hartzel cs prop and an EI wouldn't concern me (generally speaking). Guess because I've done it that way with good results. As for high compression, I thought anything above base (8:1) was high comp. I'm running whatever the Twin Comanche runs. 9:1 maybe? also used the Jeff Rose ignition on one side for a while. Now running conventional Slicks. All worked as designed. |
Hartzell has done their homework
http://www.hartzellprop.com/kitplane/index_kitplane.htm If you use a different model prop that was never on a certified plane than its an unknown. Does not mean its unsafe, just unknown. Take a stock approved engine/prop combo and modify the engine, you are back in unknown land. However to Hartzell's credit in supporting experimental homebuilders has tested electronic ignition. However the air frame even is a factor. Again Hartzell has tested RV's. Here's a spread sheet summarizing a partial list of engine/prop limits with different mods: high compression pistons, electronic ignition, exhaust and FADEC. ![]() This is all around the 360 for a reason, I explain below. Of interest to all engines is the CYA note on the bottom. Quote:
HOWEVER most effort has been on the more critical 360's, not the 320's, which as I mentioned are not as critical. If you have a specific prop and engine combo call Hartzell. If your engine is modified you may be out of luck for a definitive scientific answer. If you go with high compression pistons I am sure they have not tested it yet, or at least published that data. Hartzell does not test HC pistons very much (I asked). For one thing they don't have to. Also as a mod, high compression modifications is not as popular as electronic ignition for homebuilders, so Hartzell is less likely to test it. Remember we have experimental planes, but they do support the us and do know the effects in general of what engine mods do. Again the key word is its unknown until tested. If you go away from one of the approved combos or engine mods (aka electronic ignition) you are a "test pilot". Both HC pistons and EI (especially on the 360's) really amplify the power pulse and reduce the fatigue margins on the prop. So if you go with a IO340, or a 320 with high compression pistons and/or electronic ignition there is an UNKNOWN. However 320's in stock form are pretty mild on the props comparatively to 360's. Hartzell can do a vibration survey on any plane with any engine, modified or not, but its going to cost $8,000-$20,000? They have to instrument the plane and do flight test. If there is a popular engine or mod, they will be more likely to test it, since there is a market. If you have a one off modified engine /prop combo than you will have to pay for it. For example the new IO390 has been tested since it's likely to be a popular engine. I am sure they will get to the IO340. They need a homebuilder with that engine to volunteer to test. Quote:
I did not bring composite props up, but for the discussion composite props should be more resilient to fatigue (not immune). By definition they don't have metal blades so no metal fatigue. However the hubs are metal. The composite props are also lighter, which is considered a plus, however I am not really a fan of them. For one these compsite props come from small boutique prop companies, semi-exotic, cost more to buy / maintain and less resistance to some damage and repair of that damage is more complicated. However if I had a radical engine high with high compression, EI, cold induction and fancy exhaust, I'd consider a composite prop, if there was not a metal BA Hartzell tested. |
The standard compression ratio for an O-360 is 8.7:1 I believe.
The Secret of compression
The highest stock compression of widely produced Lycs is 9.0:1, typical of the 160 HP Cessna Skyhawk "AD" engines (eg, 320-H2AD). There where some 9.7:1 O235's that Lyc made, 125 hp. They where withdrawn from the market. In development and on the test stand they worked. In planes flown by pilots they detonated and melted pistons. ASK ME HOW I KNOW! :eek: I would be very, very, leery of going over stock or at least 9.0:1. That is my opinion. You start to get into the 9.5:1 range you have an engine that needs very careful set-up and operation. Lyc engines have compression from 6.75:1 to 9.7:1, with the most in the 8.5:1 range (parallel head) or 8.7:1 for angle heads. I think this fact is a hint from lycoming who has been building engines for 100 years and aircraft engine for 70 years. They found the formula for reliability. 8.5:1 (8.7:1 for angle valve) is the sweet spot for power, fuel and reliability, IMHO. Except for the 125 hp mistake Lyc made with the 9.7:1 O235's, the highest compression they have is 9.0:1. Of course that engine is not highly regarded for other reasons. I believe the pistons and combustion chamber are different on those "AD" engines, so 9 to 1 is not the same as it would be to a typical 320/360. A side note. It is a miss conception of some I have talked to that the 200 HP, IO-360 gets its extra 20 HP from either the Fuel Injection and/or 0.2 bump on compression. Actually it's better breathing of the angle valve head and better combustion chamber. If you went to 8.7:1 on a standard parallel valve 180HP, 360, it would add very little (2 hp?) In fact a 0.5:1 bump is not that much extra hp. For every ONE increase in compression ratio its about 6.6 to 9.2 HP. So going from 8.5:1 to 9:0:1 (1/2 bump) on a 180HP 360 is about 4-5 hp. 4 HP is good for about 1.5 mph top speed. I would rather keep the lower stock compression. Look at an O320, 150HP v 160HP. 10 HP is a pretty good bump, but that is going from 7.0:1 to 8.5:1. That is a big jump in compression, but 8.5:1 is still conservative. The nice part about 150 HP with 7.0:1 comp is you can run on 80 octane. I'm NOT for autogas in RV's (hot engine cowl, vapor lock, handling issues, availability) but its an option for some. Bottom line: The increase in compression for a little more HP is not worth it TO ME. However those considering it, think about it carefully. It does take extra attention to operate and you are giving something away. There are no free lunches. You are lowering your "detonation margins". Add experimental ignition timing advance, even if partially limited, you are a test pilot. Than FUEL availability may be an issue in the future. Does anyone remember 130 octane purple gas? That must have been some juice. |
When I rebuilt my O-320-E3D, I went to 9.5:1. The gain in hp is not worth the decrease in smoothness to me. If I had it to do over, I would not go above 9:1; maybe not even that.
I suppose I?m still confused about the definition of ?high compression?. I thought that the 0-320 160hp with the 8.5:1 pistons was considered ?high compression? as compared to the 0-320 150hp with the 7:1 compression ratio, but I guess it's only 'higher'? What is the level that is considered ?high compression?? Anything 8.75:1 or above, or 9:1 and above? |
As with everything else, there may be exceptions to this rule. |
Thanks Gary! |
| All times are GMT -6. The time now is 06:43 PM. |
