IO540 Lycoming Thunderbolt vs Reg Lycoming
Is the only difference that you can paint the Thunderbolt? They seem to have the same HP. The reg experimental is 260, so it the Thunderbolt. Both are IO540's. Is the any reason to get it or not to?
Differences
I am pretty sure you can customize the thunderbolt whereas buying the regular lycosaurus, you get what they built...
The rods and pistons are balanced and cylinders are polished and ported -- overall smoother engine. It will make more power than stock. They also dyno and test run on the bench. And you get to pick the color :) https://www.lycoming.com/engines/thunderbolt
I have done 25 hours of test flying on a brand new RV10 with a thunderbolt and 3 blade carbon fibre Hartzell.
I normally fly behind a stock IO540 and two blade. My observations; Don't get it painted black! No appreciable HP difference although there may be one or two. Was very smooth and it may be partly the prop, but it was smoother than our engine by a small amount. And we dynamically balance ours, the test aircraft has not seen a balance yet so the engine and prop must have been good out of the box. Lots more $$$, and even more so with the prop. Would I do it, no not likely but each to their own. YMMV |
Balanced rotating assembly, pistons, rods, etc. Roller cam. Port and polish, volumetric balancing of the cylinders.
We went with dual slick mags, we will get a CPI2 in the near future. And a Airflow Performance fuel servo. Vic Syracuse told me to get the Thunderbolt. I listened and I'm glad I did. |
I asked the same question to the Lycoming representative who gave a presentation at our local airport. His reply was they both swing big heavy weights at the end. He recommended the prop. dynamic balance, to balance the system.
These are aircraft engines; the parts need to conform to design specs, thresholds, and tolerances. The thunderbolts may conform to tighter specs and weights, but do these improvements overcome the prop/system's imbalance. |
Titan Option
For those looking for IO540, don't forget about Titan option. I recently had a Titan clone delivered. Working with James Ball and Titan team was very good. They worked with me to build\ship and IO 540 D4A5 clone minus the fuel ignition system so I can install SDS electronic ignition and fuel injection.
The engine was run 3 hours using slave ignition and injection system and then shipped to me. Pricing was very competitive and they have worked with me to resolve minor issues. The one issue for those having an engine built to keep in mind is the Van's supplied governor requires longer case studs than those on std engine. |
Why not black?
I'm looking at this exact set-up for my -10 build. What was your average fuel burn rate? |
| All times are GMT -6. The time now is 05:00 AM. |
