VAF Forums
-   GPS (https://vansairforce.net/community/forumdisplay.php?f=39)
-   -   Judging GPS Receiver Reliability... (https://vansairforce.net/community/showthread.php?t=16766)
OldAndBold 04-07-2007 03:10 PM
I wonder if I could get a feel for the relative reliability of typical GA GPS receivers.
1) Has anyone ever had a GPS receiver fail in flight - not loss of signal but the unit itself decided to die?
1.5) What about lockups - the unit gets to a condition where it cannot repond to button presses?
2) Has anyone ever had a GPS receiver show up NOGO at preflight?
3) Any experiences of GPS signals suddenly becoming unusable or significantly reduced accuracy during flight? If so, how long, how unusable?
Thanks in advance,
n5lp 04-07-2007 04:04 PM
You didn't ask this one, but I have had a GPS receiver (Garmin 396) completely lock up during flight. Had to remove the battery to get it to restart.
BrickPilot 04-07-2007 04:14 PM
396 failures
Same here, multiple 396 in flight lockups (buttons would not respond). I had to send two 396's back, but haven't had a peep of a problem from the one I have now, and it's been solid for over 18 months.
dlloyd3 04-07-2007 04:25 PM
A few years ago the GX55 in my Bonanza went bezerk on the takeoff roll from LGC. Shortly it show me passing 400 knots, the map seemed to tie into the high speed. By the time I reached home it showed me over the ocean. Called Garmin and they had me do a hard reset. No problems before or since, 8 years and 2000 hours.
Couple times a year it will show me 50 miles off course for 15 seconds or so. Garmin said it was great technology, not perfect.
AlexPeterson 04-07-2007 06:08 PM
A friend had his 430 go goofy on him, turns out the data card went bad.
I also have a 430, and have seen the RAIM warning a few times, usually only for a few seconds. But, speeds and positions have been corrupted during those periods. This is why for gps approaches, a RAIM system is highly suggested (Receiver Autonomous Integrity Monitoring).
OldAndBold 04-07-2007 06:18 PM
Lockups?!? Yikes!
OK, I guess I hadn't thought of asking about lockups - I would have liked to think that anything meant for an airplane (or made by Garmin!) would have software of sufficient quality that it NEVER locks up. Guess I need to ask.
...it amazes me that airplane software can be considered ready for the end user that is in any way shape or form able to "lock up". Speaking as a software engineer, there really is no excuse for that... Yikes!
L.Adamson 04-07-2007 08:11 PM
But it happens! Doesn't it...
Solution --- take along "two" GPS's, for those momentary glitches.
n5lp 04-07-2007 08:32 PM
Earlier in this thread I reported on my Garmin 396 lockup, but I forgot that earlier, my panel-mount Apollo 360 (now Garmin) unit failed in a more dangerous way. It started showing high speeds and erroneous positions, but gradually. That took a trip to the factory to fix.
Many years ago, I had a Loran start to show very subtle but worse and worse errors on an IFR flight. This was a flight along the US Mexico border and I am glad I didn't make any bad mistakes.
At this point, some sort of cross-check is certainly necessary. I guess that is a big point of the IFR units.
Ironflight 04-07-2007 08:39 PM
That's why I have three different GPS's in my system - all with different software.
And if the constellation goes away....I still have VOR.
If THEY go away, I have two Comms to call for help.
It's all about having a backup plan - never be totally dependent on any one thing.
Paul
OldAndBold 04-07-2007 09:43 PM
Shouldn't happen.
Paul
Point is, that not one of the three different GPS's software should ever do what I am hearing that it can do. Troubling. Between hardware watchdog timers and multi-tasking OSs there really isn't a good reason why a user should ever see the system lockup. Need some better software architecture over there at Garmin I think.
I was in an interview recently for a software job in SF. The firm was developing wearable computers for soldiers. It was based on Windows. The guy had no problem he said with getting Windows programmers, but a hard time getting embedded programmers. "It's easy" he said, "to teach an embedded programmer how to do Windows. It's hard to teach a Windows programmer to do embedded." I fear that too much of the Windows mindset is filtering into embedded programming (and our avionics).
"We don't know why your unit locked up (they should!). Try cycling power and see if that clears the problem (the software should already be able to do that itself!). Otherwise, send it back to us and we will install the latest firmware and hope that fixes the problem (they should already know for sure if it will fix the problem!)." Sheesh...
