http://survincity.com/2015/09/27-000-feet-in-an-rv-7/ :) CJ |
Check out this article about using welders oxygen. Oxygen is oxygen he says and that's what we have been using. I'm not dead yet. https://www.avweb.com/news/pelican/182079-1.html I have the mountain high 02 D2 system and I love it. I use very little oxygen And it works very well. :rolleyes: CJ |
https://en.wikipedia.org/wiki/Bohannon_B-1 https://airandspace.si.edu/support/w...bruce-bohannon |
Pressure or Density Altitude
Skylor |
Another potential member
It was so cold my fingers and brain missed the altimeter adjustment by .01. Hope this and the dirty screen is forgiven.
Flying home from Arizona last weekend. I should have also turned into the wind, slowed to approach speed and flew backwards, but I was too cold so I pushed on and around the weather. You can see my deviation from the flight plan to avoid further weather. ![]() |
It can get cold up there for sure, and our RV heaters are not known to be all that good. I bought one of those 12-volt heated jacket liners a while back that the motorcycle and snowmobilers use and wore that under my regular jacket for the recent trip KMDD-KHOT, at 17,000 the OAT was variable between +12 and +8 F and after about 20 minutes the cold started to soak into me pretty good. I plugged in the jacket and turned it on and it nearly roasted me on high, I kicked it down to the lowest setting and it was right on target, that made it completely comfortable.
Also happy with the Mountain High O2D2
+1. It's a tremendous gadget, really cuts down on the O2 usage. Looks like they recently introduced an improved model, as well.
I was pondering getting my own setup to fill O2 tanks but discovered that my local scuba guy (been buying stuff from him for years....) will fill my cylinder for $10. And with the O2D2 a cylinder lasts a loooong time. So I just go the scuba route. Quote:
| All times are GMT -6. The time now is 06:57 AM. |
