Need carberator help
I have a RV-9, 0-320, 160hp. My Marvel MA4-SPA (105217) is getting well worn. When I originialy built I had to drill out the main jet with a #19 bit if I remember correctly. What model carberator should I buy to replace it with out having to drill out a new main jet. Thanks
try these guys
I've used these guys for many years. Fuel injection Pitts S2A, Christen Eagle, Stearman(currently flying), Super Cub with a Marvel MA like yours. They've been around a very long time and are convenient for you.
Aircraft Carburetor & Injection Service of Texas FAA Repair Station IOFR546Y P.O. Box 399 Justin, Texas 76247 www.aircraftcarbs.com tel: 940 648-2277 |
You could send it straight to Marvel for a overhaul. Tell them the engine it's on and about the jet size. I was happy with their service.
https://www.aircraftspruce.com/catalog/pdf/Facet%20Marvel%20Schebler%20Carburetor%20Cross%20R eference%20and%20Engine%20Application.pdf |
When my then new to me RV-9A had high EGT, I called the factory and told them what was going on. They recommended a carb that I bought from Aircraft Spruce, and I think it was an exchange. That carb was richer than the previous carb, and it almost did what I wanted. The factory suggested I send that carb back to them for adjustment. I did, they did, and all was well.
I also asked about drilling out the jet, and I found out that is a really, really bad idea. My contact was: Mark Keeney Jr. Marvel-Schebler A/C Carburetors 125 Piedmont Ave. Gibsonville NC 27249 Mark@msacarbs.com (336)446-0002 Office (336)446-0007 Fax 1 855-672-2272 TF |
| All times are GMT -6. The time now is 02:06 PM. |
