VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Edge distance for F-796B (https://vansairforce.net/community/showthread.php?t=166768)
Draker 12-12-2018 07:54 AM
I've gone through a couple of angles, having a heckuva time getting correct edge distance on the F-796B angle that holds the fuel tank attach bracket. This angle nestles against the F-902 bulkhead in such a way that maintaining edge distance on the lower (#12 screw) hole is impossible. I'll see if I can get some pics of my "best" effort. Lots of scrap being produced on this one. Any tips? Anyone have a picture of a correctly constructed piece?
wirejock 12-12-2018 08:39 AM
F796B L&R
I have a couple photos and a description on my blog if it helps. I do remember it was a pain. More pain trying to get at the nuts. I made a set of this wall sockets for that. Buy sockedits from the Thrift Store and grind them down. Cheap tools.
Draker 12-12-2018 08:56 AM
Thanks again, Larry. Yours actually looks as close to the edge as mine. Might have to double check my measurement. I?m still afraid once I open it up to #12 I bust distance.
PilotjohnS 12-12-2018 09:19 AM
Who you gonna call?
I had the same dilemma, even ordered parts to remake. But a quick email to Vans and they replied with a return phone call and we found an adequate solution. Great service from Vans support. And now it is documented, so if there ever is a question, I have an official response.
wirejock 12-12-2018 09:44 AM
796
Ryan
Keep us posted. If it's nested right in the space there's nothing else that can be done. A call to Vans to document as mentioned might be in order. I still think I hit the edge distance because I always mark parts before drilling.
That said, there's several places on the fuse where it was impossible and I asked Vans to confirm.
mfleming 12-12-2018 11:14 AM
So for all the builders that we see this thread and have the same dilemma ....please share Van?s solution :D
Draker 12-18-2018 11:27 AM
Advice from Vans was to get as much edge distance as possible.
If you do the math it?s actually impossible to get sufficient distance:
According to the plans, the holes must be centered 15/32" from the forward edge of the angle. Since this is 3/4" angle, this means the hole must be centered 3/4? minus 15/32" = 9/32" from the aft edge of the angle. The plans also suggest the center of the hole is approx. 9/32? vertically from the top edge.
The final size of these holes will be 3/16" and #12. A 3/16" hole centered 9/32? from an edge leaves 3/16? edge distance which is obviously too small. That?s the best case if you?re right on the money with your drilling. Best I got was 5/32? and I?m going to leave that as is.
Tommy123 12-18-2018 08:53 PM
I can't understand why vans uses fractions when industry standard is thousands of a inch. It's not like the scales are rare.
I worked at falcon jet for a few weeks, **** millimeters!
